I've setup Ubuntu via Wubi recently for a friend and he came back with a complaint: On reboots the Windows partition is always selected by default, figured this was just a need to update Grub but realized that Wubi writes to the Windows Boot Manager and does not use Grub.
Though this is technically a "Windows" question I wasn't able to find a clear answer for this.
How to do I modify the boot/selection order for Operating systems (Mainly Ubuntu via Wubi) on the Windows Boot Manager?
Marco Ceppi
  • 48,827
The Wubi Guide on the Ubuntu wiki (manual uninstall section) gives some hints on how to edit the Windows Boot Manager boot order in Vista and XP.
In Windows Vista you can either use EasyBCD or modify the boot menu via Control Panel (Classic View) > System > Advanced system settings; then choose "Settings..." under Startup and Recovery.
In Windows XP, edit C:\boot.ini.
According to this Wubi HowTo, the default OS can be changed in Windows 7 by going to Control Panel > Advanced System Settings, and in the Default operating system drop-down selecting Ubuntu instead of Windows.
crenshaw-dev
  • 32,852
Click start and run msconfig(in Windows). Look for the Boot tab and change the order of the OS. I can't remember what it looks like its been a while, but its pretty self explanatory.
Good Luck and happy Ubuntuing!
Curtis
