28
I installed Ubuntu 16.04 (dual boot with Win 10) and it doesn't login after. I upgraded from Ubuntu 15.10 via update-manager
I have tried old workarounds for previous versions, like:
  • dpkg-reconfigure lightDM
  • chown user:user .Xauthority
  • chmod 666 .Xauthority
  • chmod a+wt /temp
  • mv .Xauthority smth
  • apt-get install ubuntu-session
  • Reinstalling Nvidia Drivers
Any suggestions appre
Java Jedi
  • 281
5 Answers5
32
I was in the same situation as you.
I did not reinstall nvidia drivers but remove it.
sudo apt-get purge nvidia*
And it worked.
d a i s y
  • 5,551
Nuno
  • 321
On all my systems (all had the same problem) the solution was:
  • Switch to console using Ctrl+Alt+F1
  • Login to text console (your username is enough if your system only has one user. otherwise you will need root user or sudo)
  • rm /home/*/.Xauthority
  • reboot
Daniel Alder
  • 2,612
I ran into the same problem on my upgrade to 16.04 from 15.10. I recalled that during the upgrade, there was a prompt regarding UEFI Secure Boot options. I checked my BIOS settings and sure enough, Secure Boot was set to "Windows Only". I selected "Other OS" from the list (your options may be different) and booted normally. All fixed.
Have not seen any other mentions of this fix so hopefully this will help.
I have this problem to. This problem reason is the new Unity match with 4.4.0 kernel version, and your kernel version same as 4.2.x now You have 2 solution for this problem:
  1. temp: install another desktop env same as gnome,lxde,or etc...
  2. or update the kernel.
for run the command before or after loop ctrl+alt+F1:
for check kernel version: send this command
$ uname -a
and fore update kernel :
http://ubuntuhandbook.org/index.php/2016/01/how-to-install-linux-kernel-4-4-in-ubuntu/
for install other desktop env googling about your desktop env.
A1Gard
  • 260
I just tried Nuno's idea.. Negative for me.. still stuck in the login loop on Console-7.. But, able to log in via console 1 (TTY1).. I also ran into this back when i went the route of 12.10 to 13.x (both), and it landed in the same loop.. Only workaround I could find, was using an old "Installed" software list from Synaptic, doing a fresh install of 13.04, and also doing the same when i bumped up to 15.04. , getting Synaptic loaded 1st, and then reading in the old software list.
