I have problems when installing the tool and performing upgrades in Ubuntu 14.04 LTS. Please assist me
Fetched 6738 kB in 1min 19s (85.1 kB/s)
perl: warning: Setting locale failed.
perl: warning: Please check that your locale settings:
LANGUAGE = "en",
LC_ALL = "en_GB.UTF-8",
LC_TIME = "id_ID.UTF-8",
LC_MONETARY = "id_ID.UTF-8",
LC_ADDRESS = "id_ID.UTF-8",
LC_TELEPHONE = "id_ID.UTF-8",
LC_NAME = "id_ID.UTF-8",
LC_MEASUREMENT = "id_ID.UTF-8",
LC_IDENTIFICATION = "id_ID.UTF-8",
LC_NUMERIC = "id_ID.UTF-8",
LC_PAPER = "id_ID.UTF-8",
LANG = "en_US.UTF-8"
are supported and installed on your system.
perl: warning: Falling back to the standard locale ("C").
Can't exec "locale": No such file or directory at /usr/share/perl5/Debconf/Encoding.pm line 16.
Use of uninitialized value $Debconf::Encoding::charmap in scalar chomp at /usr/share/perl5/Debconf/Encoding.pm line 17.
Unescaped left brace in regex is deprecated, passed through in regex; marked by <-- HERE in m/^(.*?)(\\)?\${ <-- HERE ([^{}]+)}(.*)$/ at /usr/share/perl5/Debconf/Question.pm line 72.
Unescaped left brace in regex is deprecated, passed through in regex; marked by <-- HERE in m/\${ <-- HERE ([^}]+)}/ at /usr/share/perl5/Debconf/Config.pm line 30.
Preconfiguring packages ...
dpkg: warning: 'ldconfig' not found in PATH or not executable
dpkg: error: 1 expected program not found in PATH or not executable
Note: root's PATH should usually contain /usr/local/sbin, /usr/sbin and /sbin
E: Sub-process /usr/bin/dpkg returned an error code (2)
sudo apt-get install locales
Reading package lists... Done
Building dependency tree
libc6 : Breaks: locales (< 2.22) but 2.13+git20120306-12.1 is to be installed
Recommends: libc6-i686
E: Error, pkgProblemResolver::Resolve generated breaks, this may be caused by held packages.
sudo apt-get install libc6-i686
Package libc6-i686 is a virtual package provided by:
libc6 2.19-0ubuntu6.7 [Not candidate version]
libc6 2.19-0ubuntu6 [Not candidate version]
E: Package 'libc6-i686' has no installation candidate
