10
I want to rename file name with its parent folder name, adding the folder name before the current name.
for example:
Folder structure
SOCH NC KT 633-ROYAL BLUE-MULTI
Expected Result
SOCH NC KT 710-BLACK-MULTI
Could anyone advise how this can be done in a .sh file? Is there any utility is available to do the operation?
dessert
  • 40,956
Neo
  • 135
6 Answers6
You can do this with rename:
rename -n 's/(.*)\//$1\/$1/' */*
This command needs to be started in the directory directly above the directories you want to process. It will first only list the changes for you to check, if you're happy with the results run it without -n to perform the renaming.
Example run
$ tree
└── SOCH NC KT 633-ROYAL BLUE-MULTI
$ rename 's/(.*)\//$1\/$1/' */*
$ tree
Explanation
  • s/a/b/substitute a by b
  • (.*)\/ – take everything until (excl.) the last slash saving it as group 1 and substitute it by
  • $1\/$1 – group 1 (dir name), a slash and group 1 again (file name prefix)
dessert
  • 40,956
In a small python script, renaming files recursively (folders as well as sub folders):
#!/usr/bin/env python3
import shutil
import os
import sys
dr = sys.argv[1]
for root, dirs, files in os.walk(dr):
    for f in files:
        shutil.move(root+"/"+f, root+"/"+root.split("/")[-1]+f)
How to use
  • Copy the script into an empty file, save it as rename_files.py
  • Run it with the directory as an argument:
    python3 /path/to/rename_files.py /directory/with/files
Note
As always, first try on a sample!
Explanation
The script:
  • Walks through the directories, looking for files.
  • If files are found, it splits the path to the file with the delimiter "/", keeping the last in the row (which is the parent's folder name) , to be pasted before the file's name:
    root.split("/")[-1]
  • Subsequently, move the file to the renamed one:
Jacob Vlijm
  • 85,475
Using only shell (bash) with a little help from mv:
#!/bin/bash
shopt -s globstar  ##globstar will let us match files recursively
files=( /foo/bar/**/*.jpg )  ##Array containing matched files, mention where to search and what files here
for i in "${files[@]}"; do
    d="${i%/*}"  ##Parameter expansion, gets the path upto the parent directory
    d_="${d##*/}"  ##gets the name of parent directory
    f="${i##*/}"  ##gets the file name
        echo mv "$i" "$d"/"${d_}""$f"  ##renaming, remove echo after confirming what will be changed and you are good
done
Example:
$ shopt -s globstar
$ files=( /foo/bar/**/*.jpg )
$ for i in "${files[@]}"; do d="${i%/*}"; d_="${d##*/}"; f="${i##*/}"; echo mv "$i" "$d"/"${d_}""$f"; done
mv /foo/bar/KT/633-ROYAL/4.jpg /foo/bar/KT/633-ROYAL/633-ROYAL4.jpg
mv /foo/bar/KT/633-ROYAL/5.jpg /foo/bar/KT/633-ROYAL/633-ROYAL5.jpg
mv /foo/bar/KT/633-ROYAL/6.jpg /foo/bar/KT/633-ROYAL/633-ROYAL6.jpg
mv /foo/bar/KT/633-ROYAL/BLUE-MULTI/1.jpg /foo/bar/KT/633-ROYAL/BLUE-MULTI/BLUE-MULTI1.jpg
mv /foo/bar/KT/633-ROYAL/BLUE-MULTI/2.jpg /foo/bar/KT/633-ROYAL/BLUE-MULTI/BLUE-MULTI2.jpg
mv /foo/bar/KT/633-ROYAL/BLUE-MULTI/3.jpg /foo/bar/KT/633-ROYAL/BLUE-MULTI/BLUE-MULTI3.jpg
heemayl
  • 93,925
Bash solution, executing from folder where filenames you want to change are placed. You have to change workdir to your path
#!/bin/bash
shopt -s globstar
workdir="/path/to/your/dir"
for folder in $workdir/**/*;do
  if [[ -d "$folder" ]]; then
    for file in "$folder"/*;do
        if [[ -f "$file" ]]; then
            fi="`basename "$file"`"
            fo="`basename "$folder"`"
            mv "$file" "$folder/$fo$fi"
        fi
    done
  fi
done
It will change all files in all directories recursively from your workdir .
EdiD
  • 4,617
  • 27
  • 41
Here's a small example of how that can be done form the directory you want to edit.
$> ls
file1.txt  file2.txt  file3.txt
$> pwd
/home/xieerqi/testing_dir
$> find . -type f -printf "%f\0" | \
> while IFS="" read -d "" filename ; do \
> echo $filename ${PWD##*/}_$filename   ; done
file2.txt testing_dir_file2.txt
file1.txt testing_dir_file1.txt
file3.txt testing_dir_file3.txt
Replace echo with mv or cp for copying or moving as necessary
Yet another bash-only approach, to be executed in the folder where the files that need renaming reside:
for f in * ; do mv "$f" "$(basename "$(pwd)")"_"$f" ; done
This will also handle file and folder names with spaces.
vanadium
  • 97,564
