I messed up and ran chown -R username:username / by accident.
I rebooted into recovery mode to get root privileges back and did the following...
mount -o remount,rw / to get write permissions, then
chown root:root /usr/bin/sudo
chmod u+s /usr/bin/sudo
to get sudo working again.
I then chown root:root on every directory but my home directory to get the ownerships back.
Something still isn't right though because the update-manager is not working.
/usr/bin/update-manager gives me these errors.
Traceback (most recent call last):
  File "/usr/lib/python3/dist-packages/dbus/bus.py", line 175, in activate_name_owner
    return self.get_name_owner(bus_name)
  File "/usr/lib/python3/dist-packages/dbus/bus.py", line 361, in get_name_owner
    's', (bus_name,), **keywords)
  File "/usr/lib/python3/dist-packages/dbus/connection.py", line 651, in call_blocking
    message, timeout)
dbus.exceptions.DBusException: org.freedesktop.DBus.Error.NameHasNoOwner: Could not get owner of name 'org.debian.apt': no such name
During handling of the above exception, another exception occurred:
  File "/usr/lib/python3/dist-packages/defer/__init__.py", line 487, in _inline_callbacks
    result = gen.send(result)
  File "/usr/lib/python3/dist-packages/aptdaemon/client.py", line 1613, in _run_transaction_helper
    daemon = get_aptdaemon(self.bus)
  File "/usr/lib/python3/dist-packages/aptdaemon/client.py", line 1701, in get_aptdaemon
    False),
  File "/usr/lib/python3/dist-packages/dbus/bus.py", line 241, in get_object
    follow_name_owner_changes=follow_name_owner_changes)
  File "/usr/lib/python3/dist-packages/dbus/proxies.py", line 248, in __init__
    self._named_service = conn.activate_name_owner(bus_name)
  File "/usr/lib/python3/dist-packages/dbus/bus.py", line 180, in activate_name_owner
    self.start_service_by_name(bus_name)
  File "/usr/lib/python3/dist-packages/dbus/bus.py", line 278, in start_service_by_name
    'su', (bus_name, flags)))
    message, timeout)
dbus.exceptions.DBusException: org.freedesktop.DBus.Error.Spawn.ExecFailed: Failed to execute program org.debian.apt: Permission denied
    message, timeout)
    False),
    message, timeout)
  File "/usr/lib/python3/dist-packages/aptdaemon/client.py", line 1573, in _run_transaction
    async)
  File "/usr/lib/python3/dist-packages/defer/__init__.py", line 597, in unwind_generator
    return _inline_callbacks(None, func(*args, **kwargs), Deferred())
  File "/usr/lib/python3/dist-packages/defer/__init__.py", line 533, in _inline_callbacks
    deferred.errback()
  File "/usr/lib/python3/dist-packages/defer/__init__.py", line 359, in errback
    self._next()
  File "/usr/lib/python3/dist-packages/defer/__init__.py", line 415, in _next
    self.result.traceback)
  File "/usr/lib/python3/dist-packages/apport_python_hook.py", line 123, in apport_excepthook
    with open(pr_filename, 'rb') as f:
PermissionError: [Errno 13] Permission denied: '/var/crash/_usr_bin_update-manager.1000.crash'
