On Ubuntu 14.04 I got used to run during the boot process a python script for conky to read my GPU temperature and then change my FAN speed according to the temperature. This is the script:
# python /home/ibart/.scripts/ventola_ati.py
import os
import time
minTemp = 45.00
maxTemp = 70.00
minSpeed = 10
maxSpeed = 90
updateInterval = 3
fanSpeed = 25
while True:
    f = os.popen('aticonfig --od-gettemperature | grep "Sensor 0" | cut -c43-47')
    currentTemp = eval(str(f.readlines())[2:7])
    if currentTemp > maxTemp:
        if fanSpeed < maxSpeed:
            fanSpeed = fanSpeed + 1
    if currentTemp < minTemp:
        if fanSpeed > minSpeed:
            fanSpeed = fanSpeed - 1
    os.system('aticonfig --pplib-cmd "set fanspeed 0 ' + str(fanSpeed) + '"')
    print fanSpeed
    print currentTemp
    time.sleep(updateInterval)
What now that Ubuntu dropped the official drivers for my card, an old and fancy HD5770?
Thanks.
edit. On 16.04 sensors detects it. Thanks Luca.
Mich. Gio.
  • 213
Please use sensors-detect.
sudo sensors-detect
then launch it with:
sensors
I assume you are trying to change the speed of the system fan in response to the GPU temperature. I think the speed of the GPU fan can only be controlled by the GPU driver (if at all).
Install 'lm-sensors' and 'fancontrol'. There is an excellent set of instructions for doing so here
From the fragment of the output from sensors you have posted it seems you have installed but not configured lm-sensors. You do so by finding or writing a configuration file for your motherboard and placing it in /etc/sensors.d
As sensors is apparently reporting the GPU temperature correctly you don’t need to bother to do this if you don’t mind spurious readings from non-existent sensors and spurious warnings.
Then configure 'fancontrol' to have the fan speed controlled by the GPU temperature.
Steve Roome
  • 1,429
