MY FIRST STEP IN THE TERMINAL:
aivinor@mcph:~$ sudo apt-get install ttf-mscorefonts-installer
Reading package lists... Done
Building dependency tree
The following packages were automatically installed and are no longer required:
  imagemagick-common liblqr-1-0 libmagickcore5 libmagickcore5-extra
  libmagickwand5 libnetpbm10 linux-headers-3.13.0-32
  linux-headers-3.13.0-32-generic linux-image-3.13.0-32-generic
  linux-image-extra-3.13.0-32-generic netpbm
Use 'apt-get autoremove' to remove them.
The following extra packages will be installed:
  cabextract
The following NEW packages will be installed:
  cabextract ttf-mscorefonts-installer
0 upgraded, 2 newly installed, 0 to remove and 32 not upgraded.
Need to get 70.6 kB of archives.
After this operation, 282 kB of additional disk space will be used.
Do you want to continue? [Y/n] y
MY SECOND STEP:
 WARNING: The following packages cannot be authenticated!
   Install these packages without verification? [y/N] y
   0% [Connecting to 172.16.19.10 (172.16.19.10)]
   Err http://in.archive.ubuntu.com/ubuntu/ trusty/universe cabextract amd64 1.4-4
AT THIS POINT I FACE A NUMBER OF ERRORS THAT CLAIM INABILITY TO CONNECT TO 172.16.19.10 AS CONNECTION TIMED OUT - I HAVE NO INTERNET PROBLEMS SAYS FAILED TO FETCH AND HAS LINKS SUCH AS
in.archive.ubuntu.com/ubuntu/ trusty/multiverse ttf-mscorefonts-installer all 3.4+nmu1ubuntu1
in.archive.ubuntu.com/ubuntu/pool/universe/c/cabextract/cabextract_1.4-4_amd64.deb
in.archive.ubuntu.com/ubuntu/pool/multiverse/m/msttcorefonts/ttf-mscorefonts-installer_3.4+nmu1ubuntu1_all.deb
LAST LINE IS:
E: Unable to fetch some archives, maybe run apt-get update or try with --fix-missing?
mikeymop
  • 861
  • 18
The problem seems to be related with network connection.
So, first check if your PC is connected to your router:
ifconfig
The above command will show you PC network interfaces. Now look at the command output and search the inet addr. It should be in the second line of one of your connected interface (under something like eth0 or wlan0 depending if your are connected via cable or through WI-FI). If the value of your inet addr is similar to 172.16.x.x your PC is in the same network of your router.
If it is not so you have to reconnect to your router. You can do this with Network Manager.
Now you can check the connection between your PC and your router with this command:
ping 172.16.19.10
If it works you can check connectivity with internet:
ping www.google.com -c 8
If also this works, you can install fonts as suggested by @mikeymop:
sudo apt-get update
sudo apt-get install ubuntu-restricted-extras
If ping command didn't work it means 2 things:
  1. ICMP packets cannot be sent over your network or out of it.
  2. You can't reach your router or external server (e.g. www.google.com)
In the first case you could try to check your connectivity directly running
 apt-get update
In the other case you can try to reboot your router and you have to hope that all things will work after.
I hope this could help you.
Danibix
  • 2,185
-1
Have you tried
$sudo apt-get update && sudo apt-get install ubuntu-restricted-extras
This package, includes the Microsoft fonts
mikeymop
  • 861
  • 18
