I wanted to try installing THELI (https://www.astro.uni-bonn.de/theli/) on my Ubuntu machine. In the installation notes it says that it needs qt3, and not qt4 or 5, for the GUI to work properly. I followed the instructions on the installations page and added:
deb http://debian.tryphon.eu jessie main contrib
deb-src http://debian.tryphon.eu jessie main contrib
to my /etc/apt/sources.list, which works as it should. But now when I use:
sudo apt-get install qt3-dev-tools
I get the following error:
qt3-dev-tools : Depends: libjpeg62-turbo (>= 1.3.1) but it is not installable
Depends: libqt3-mt (>= 3:3.3.8b) but it is not going to be installed
Recommends: libqt3-mt-dev but it is not going to be installed
So what I took from that is, that libjpeg62-turbo was the problem here. After a little fiddling around I got apt to also install the libtools62-turbo which is an i386-Package (I think I got it working at least). After a new try of installing the qt3-dev-tools I still get the same error message, even though apt told me before that libjpeg62-tools was successfully installed.
I also tried to build qt3 from source, but that didn't work as well because I got some kind of error during the make-phase.
I would very much appreciate it if someone could help me figure out what I am doing wrong.
