21
After searching everywhere I have not managed to find a specific answer for my question.
On Windows there is an application called FTPbox that will automatically sync a local folder with an ftp one every set period of time.
My question is, how do I achieve the same thing using Ubuntu? The main thing is here that I dont want to have to do it manually. It needs to be a totally automatic process with no human intervention required (obviously I will have to set this up if that classes as human intervention LOL).
Many thanks in anticipation for helpful answers.
-Edward
Edward Nunn
  • 323
First solution
Install lftp
sudo apt-get install lftp
after that create script
#!/bin/bash
HOST='mysite.com'
USER='myuser'
PASS='myuser'
TARGETFOLDER='/new'
SOURCEFOLDER='/home/myuser/backups'
lftp -f " open $HOST user $USER $PASS lcd $SOURCEFOLDER mirror --reverse --delete --verbose $SOURCEFOLDER $TARGETFOLDER bye "
Save it on some place with name upload.sh. Give it +x permission.
sudo chmod +x /path_to_script/upload.sh
Setup crontab to run this command on every x period of time
For editing crontab run
crontab -e
For running command on every 5 min code is
 */5 * * * * /path_to_script/upload.sh
on every hour
 0 */1 * * * /path_to_script/upload.sh
to run on 4 am
 0 4 * * * /path_to_script/upload.sh
Solution two
Create a small and easy script called lftp-script that LFTP can read:
open ftp://username:password@website.com
mirror --reverse -v --only-newer /home/local/path/ /website.com/public_html/
Finally you can run LFTP and start the synchronisation. Set crontab like I write but put command
lftp -f /path/to/lftp-script
something like this
 */5 * * * * lftp -f /path/to/lftp-script
Solution three
Install curlftpfs
sudo apt-get install curlftpfs
you need to do in order to mount ftp locally is to to run these commands create dir witch will be sync-ed
mkdir hostr
mount remote ftp dir to local
sudo curlftpfs -o allow_other ftp://user:pass@ftp.example.com host
user:pass is the username and password to log into ftp account.
You can add curlftpfs to fstab for automatic mounting by using this line :
curlftpfs#user:pass@ftp.example.com /mnt/host fuse rw,uid=500,user,noauto 0 0
2707974
  • 10,758
