So I'm a newbie to Linux in general and installed Steam on a VM to sort of test it out. I installed Steam to check what games are available in Linux and stuff but I just doesn't open. I double click the desktop icon and nothing happens.
I downloaded it from Steam's website and installed the package normally.
Running Steam on ubuntu 15.10 32-bit STEAM_RUNTIME is enabled automatically Installing breakpad exception handler for appid(steam)/version(0) pci id for fd 7: 80ee:beef, driver (null) libGL error: core dri or dri2 extension not found libGL error: failed to load driver: vboxvideo libGL error: unable to load driver: swrast_dri.so libGL error: failed to load driver: swrast
EDIT: New problem. Now when I start Steam, the little update box appears for a couple of seconds and the terminal gives me this error:
Running Steam on ubuntu 15.10 32-bit STEAM_RUNTIME is enabled automatically Installing breakpad exception handler for appid(steam)/version(1459463254) pci id for fd 7: 80ee:beef, driver (null) libGL error: core dri or dri2 extension not found libGL error: failed to load driver: vboxvideo Installing breakpad exception handler for appid(steam)/version(1459463254) Installing breakpad exception handler for appid(steam)/version(1459463254) Installing breakpad exception handler for appid(steam)/version(1459463254) Fontconfig error: "/etc/fonts/conf.d/10-scale-bitmap-fonts.conf", line 70: non-double matrix element Fontconfig error: "/etc/fonts/conf.d/10-scale-bitmap-fonts.conf", line 70: non-double matrix element Fontconfig warning: "/etc/fonts/conf.d/10-scale-bitmap-fonts.conf", line 78: saw unknown, expected number pci id for fd 23: 80ee:beef, driver (null) libGL error: core dri or dri2 extension not found libGL error: failed to load driver: vboxvideo [0417/235119:ERROR:main_delegate.cc(777)] Could not load cef_extensions.pak [0417/235119:ERROR:browser_main_loop.cc(203)] Running without the SUID sandbox! See https://code.google.com/p/chromium/wiki/LinuxSUIDSandboxDevelopment for more information on developing with the sandbox on. [0417/235119:INFO:audio_manager_pulse.cc(257)] Failed to connect to the context. Error: Conexão recusada Installing breakpad exception handler for appid(steamwebhelper)/version(20160331191033) Installing breakpad exception handler for appid(steamwebhelper)/version(1459451433) Installing breakpad exception handler for appid(steamwebhelper)/version(20160331191033) Installing breakpad exception handler for appid(steamwebhelper)/version(1459463254) Installing breakpad exception handler for appid(steamwebhelper)/version(1459463254) [0417/235119:ERROR:main_delegate.cc(777)] Could not load cef_extensions.pak Installing breakpad exception handler for appid(steam)/version(1459463254) Installing breakpad exception handler for appid(steam)/version(1459463254) Installing breakpad exception handler for appid(steam)/version(1459463254) Installing breakpad exception handler for appid(steam)/version(1459463254) Installing breakpad exception handler for appid(steam)/version(1459463254) Created shared memory when not owner SteamController_Shared_mem Installing breakpad exception handler for appid(steam)/version(1459463254) Installing breakpad exception handler for appid(steam)/version(1459463254) Installing breakpad exception handler for appid(steam)/version(1459463254) PulseAudio connect failed (used only for Mic Volume Control) with error: Acesso negado Fontconfig error: "/etc/fonts/conf.d/10-scale-bitmap-fonts.conf", line 70: non-double matrix element Fontconfig error: "/etc/fonts/conf.d/10-scale-bitmap-fonts.conf", line 70: non-double matrix element Fontconfig warning: "/etc/fonts/conf.d/10-scale-bitmap-fonts.conf", line 78: saw unknown, expected number LLVM ERROR: Do not know how to split the result of this operator! Bad thread local../common/steamservice.cpp (56) : Assertion Failed: m_hServiceLib == NULL Assert( Assertion Failed: m_hServiceLib == NULL ):../common/steamservice.cpp:56 Installing breakpad exception handler for appid(steam)/version(1459463254) crash_20160417235121_14.dmp[11509]: Uploading dump (out-of-process) /tmp/dumps/crash_20160417235121_14.dmp assert_20160417235115_1.dmp[11512]: Uploading dump (out-of-process) /tmp/dumps/assert_20160417235115_1.dmp /home/samuel/.local/share/Steam/steam.sh: linha 756: 11447 Falha de segmentação (imagem do núcleo gravada) $STEAM_DEBUGGER "$STEAMROOT/$STEAMEXEPATH" "$@" Refresh rate: 1 Refresh rate: 1 Refresh rate: 1 Refresh rate: 1 Refresh rate: 1 Refresh rate: 1 Refresh rate: 1 Refresh rate: 1 Refresh rate: 1 Refresh rate: 1 assert_20160417235115_1.dmp[11512]: Finished uploading minidump (out-of-process): success = yes assert_20160417235115_1.dmp[11512]: response: CrashID=bp-a7caa2ab-6060-4faf-82af-76e8d2160417 assert_20160417235115_1.dmp[11512]: file ''/tmp/dumps/assert_20160417235115_1.dmp'', upload yes: ''CrashID=bp-a7caa2ab-6060-4faf-82af-76e8d2160417'' crash_20160417235121_14.dmp[11509]: Finished uploading minidump (out-of-process): success = yes crash_20160417235121_14.dmp[11509]: response: CrashID=bp-e70cd50a-debb-4a3e-80cd-e28b92160417 crash_20160417235121_14.dmp[11509]: file ''/tmp/dumps/crash_20160417235121_14.dmp'', upload yes: ''CrashID=bp-e70cd50a-debb-4a3e-80cd-e28b92160417''
