I have problem my wifi doesnt work after resume.
I already tried lot of solution over google.
What currently I have:
cat /etc/pm/sleep.d/wakenet.sh
#!/bin/bash
case "$1" in
thaw|resume)
nmcli nm sleep false
pkill -f wpa_supplicant
esac
exit $?
cat /etc/pm/config.d/config
SUSPEND_MODULES="ath10k_pci"
Error log after resume:
 ath10k_pci 0000:04:00.0: Refused to change power state, currently in D3
[   52.941724] ath10k_pci 0000:04:00.0: failed to wake target for write32 of 0x00000000 at 0x00034400: -110
[   52.952859] ath10k_pci 0000:04:00.0: failed to wake target for write32 of 0x00000000 at 0x00034404: -110
[   52.963313] ath10k_pci 0000:04:00.0: failed to wake target for read32 at 0x00034410: -110
[   52.973762] ath10k_pci 0000:04:00.0: failed to wake target for write32 of 0xffff0000 at 0x00034410: -110
[   52.984213] ath10k_pci 0000:04:00.0: failed to wake target for read32 at 0x0003444c: -110
[   52.994663] ath10k_pci 0000:04:00.0: failed to wake target for write32 of 0xffff0000 at 0x0003444c: -110
[   53.005114] ath10k_pci 0000:04:00.0: failed to wake target for write32 of 0x00000000 at 0x00034408: -110
[   53.015563] ath10k_pci 0000:04:00.0: failed to wake target for write32 of 0x00000000 at 0x0003440c: -110
[   53.026037] ath10k_pci 0000:04:00.0: failed to wake target for read32 at 0x00034450: -110
[   53.036495] ath10k_pci 0000:04:00.0: failed to wake target for write32 of 0xffff0000 at 0x00034450: -110
[   54.332051] ath10k_pci 0000:04:00.0: pci irq legacy interrupts 0 irq_mode 0 reset_mode 0
[   57.467798] ath10k_pci 0000:04:00.0: failed to read device register, device is gone
[   57.467809] ath10k_pci 0000:04:00.0: failed to reset chip: -5
[   57.478781] ath10k_pci: probe of 0000:04:00.0 failed with error -5
uname -a
Linux sahal 4.4.0-18-generic #34~14.04.1-Ubuntu SMP Thu Apr 7 18:31:54 UTC 2016 x86_64 x86_64 x86_64 GNU/Linux
I really need help now . Thank you !
I found a solution finally! Just make this script to remove the module before suspend and reload after.
https://pastebin.com/93pAZC45
I used Owais Lone's answer to a similar question to enable automatic resume of wifi after suspension for my laptop (a Dell Precision) on 16.04 LTS.
Like Owais, I created /etc/pm/sleep.d/10_resume_wifi:
#!/bin/sh
case "${1}" in
    resume|thaw)
      nmcli radio wifi off && nmcli radio wifi on;;
esac
followed by a sudo chmod +x /etc/pm/sleep.d/10_resume_wifi.
In case you're wondering about the double semicolons or the solitary close parenthesis like I was, see http://tldp.org/LDP/Bash-Beginners-Guide/html/sect_07_03.html -- that's just how the case syntax works.
ScottH
  • 81
