Weirded out owner of the first convergence device here.
I bought a bluetooth keyboard and mouse the day the tablet showed up in the mail. The tablet is engineered to be used that way, right? Pairing, check, desktop mode, check. Open some webpage to see how everything works. "Please enter email address and password" (I must have been on facebook or something)... Epic fail: I can't type the character "@".
On a standard German layout, the "@" sign is reached with the combination of "alt gr" and "Q". There are plenty of characters that can only be reached through "alt gr": "{ ,[ ,\, ~, |".
Since then, I also found out that none of the dead keys work. To make a "ê", I'd type "^" then "e". Typing "^" doesn't do anything. Typing "e" afterwise does a regular "e". Same with every other accents and non-ascii characters that the non-anglosaxon world absolutely needs to communicate. I mean, I started writing an email in French to my mom and stopped after a while and finger-typed it on the screen, because the unaccented version didn't make any sense.
I could spend a few hours remapping the keyboard, but the "keyboards" utility we've all been enjoying since the night of the age doesn't seem to exist in Ubuntu Touch, and has been replaced with a 3-options-menu.
Before you mention it, that 3-options menu doesn't let you pick a "compose" key. And, while we're at it, I did select the correct keyboard layout. All keys produce the expected character, except the dead keys and the ones that require "alt gr".
The keyboard itself is not at fault. I paired it with an android device, and it works as expected. I'm even typing with it right now! @ é è € {[]}
sitarane
  • 100
Are you saying that the "Germany" keyboard layout is not available on the tablet's options? What type of keyboard does the tablet believe it's dealing with?
To activate the accented ASCII character combinations, you usually have to go into the system settings and tell it explicitly which "compose" key to use. That's the key that signals to the system that you're about to ask for a combo to be treated as a single alternative character.
For example, if you want to combine CTRL + "^" + "e" to get "ê" -- then your "compose" key is CTRL. You have to tell the system that one of the CTRL keys is the start of a combo.
On Macs, it's set up by default, but on most of the Linuxes I've set up recently, there's no compose key configured until you select one yourself.
To do this on desktop Ubuntu, there's a help file with instructions, here: https://help.ubuntu.com/community/ComposeKey
I don't have the Aquaris tablet yet, so I can't give you explicit instructions on the tablet version, but I bet if you get your tablet into Desktop mode, you can apply those instructions to the tablet too.
Sounds like this bug, which is targetted to be fixed in the next over the air updated, OTA-12.
https://bugs.launchpad.net/bugs/1565236
popey
  • 24,549
