I have installed a wrong version of the kernel. I want delete it because it is also visible from the grub advanced option.
simone
  • 23
Let's explain it by using an example ... boot with the kernel you want to keep, in this case kernel 4.2.0-35. To check which kernel versions currently are installed, open a terminal and execute :
dpkg --get-selections | grep linux
The output in this example shows that kernels 4.2.0-34 and 4.2.0-35 are currently installed.
linux-firmware                          install
linux-generic                           install
linux-headers-4.2.0-34                  install
linux-headers-4.2.0-35                  install
linux-headers-4.2.0-34-generic          install
linux-headers-4.2.0-35-generic          install
linux-headers-generic                   install
linux-image-4.2.0-34-generic            install
linux-image-4.2.0-35-generic            install
linux-image-extra-4.2.0-34-generic      install
linux-image-extra-4.2.0-35-generic      install
linux-image-generic                     install
linux-libc-dev:amd64                    install
linux-signed-generic                    install
linux-signed-image-4.2.0-34-generic     install
linux-signed-image-4.2.0-35-generic     install
linux-signed-image-generic              install
Assuming that the older kernel 4.2.0-34 shall be removed - execute the following command :
sudo apt-get purge linux-headers-4.2.0-34 linux-headers-4.2.0-34-generic linux-image-4.2.0-34-generic linux-image-extra-4.2.0-34-generic linux-signed-image-4.2.0-34-generic
Done! :-)
cl-netbox
  • 31,491
