I'm considering trying out GNOME and maybe changing to it, but I've heard that installing multiple desktop environments (so you can access them both from the login screen) can make your desktop do weird things.
When 16.04 releases, I would like to change my Kubuntu 15.10 KDE desktop to a GNOME one (or changing to Ubuntu GNOME 16.04?), is that possible? If not, when I upgrade, can I later change my system to Ubuntu GNOME 16.04? Can I do this without wiping my system? I do not want to reinstall everything again.
userino
  • 552
There are several desktop environments available like KDE Plasma, Cinnamon, MATE, etc. Just install it using terminal. To switch with new environment. Go-to Login screen, select setting-gear and select your newly installed environment. Installing two environments might be tedious and also create tons of junk in your device. You can try Ubuntu-Flavours which provides you with a preinstalled environment of your choice.
Of course you can. You can install any desktop you want. Maybe, if you install antoher desktop you could have some issues in design for example, maybe the desktop is not exactly like photos. If you want a full integration of Gnome with Ubuntu, try Ubuntu Gnome.
How install Gnome:
sudo apt install ubuntu-gnome-desktop
If you want to try gdm, choose gdm instead of lightdm as the display manager when prompted.
Reboot.
Note: if it turns out that gdm isn't your cup of tea you can go back to lightdm by issuing the command sudo dpkg-reconfigure lightdm and you will once again get to choose.
Elder Geek
  • 36,752
