i have server which two int. and static ip. And i need one work in local network and another work to internet. How configure interfaces ?
If you want to configure Static IP address you need to edit the /etc/network/interfaces and you need to enter the following lines replace eth0 with your network interface card
sudo nano /etc/network/interfaces
Set the primary network interface - to internet
auto eth0
iface eth0 inet static
address 192.168.xxx.xxx
gateway 192.168.xxx.xxx
netmask 255.255.255.0
then configure second interface - to lan
auto eth1
iface eth1 inet static
address 192.168.yyy.yyy
gateway 192.168.yyy.yyy
You need to enter all the details like address,netmask and gateways values after entering all the values save this file and you need to restart networking services in debian using the following command to take effect of our new ipaddress.
After entering all the details you need to restart networking services using the following command
sudo /etc/init.d/networking restart
Setting up your hostname upon a ubuntu installation is very straightforward. You can directly query, or set, the hostname with the hostname command.
As an user you can see your current hostname with
sudo /bin/hostname
Example
To set the hostname directly you can become root and run
sudo /bin/hostname newname
When your system boots it will automatically read the hostname from the file /etc/hostname
When it comes to DNS setup Ubuntu doesn't differ from other distributions. You can add hostname and IP addresses to the file /etc/hosts for static lookups.
To cause your machine to consult with a particular server for name lookups you simply add their addresses to /etc/resolv.conf.
For example a machine which should perform lookups from the DNS server at IP address 8.8.8.8 would have a resolv.conf file looking like this
sudo nano /etc/resolv.conf
enter the following details
nameserver 8.8.8.8
Now to setup traffic from internet to lan and from lan to internet
The first thing to do is do enable IP forwarding. This is done either by using
echo "1" > /proc/sys/net/ipv4/ip_forward
Then, we will add a rule telling to forward the traffic
sudo iptables -A FORWARD -i eth1 -o eth0 -j ACCEPT
sudo iptables -A FORWARD -i eth0 -o eth1 -m state --state ESTABLISHED,RELATED -j ACCEPT
2707974
  • 10,758
