I have a script that works in the background. I would like to show an icon in the panel (only) if it runs; it should not show if the script is not running, just like the Dropbox icon.
How can I achieve this? I have installed Xubuntu 14.04.
Based on (and explained in) this answer, we can fairly easily create an indicator, which runs on both Xubuntu and Unity or any other flavour, to show if a process, a script or an application runs or not.
script runs:
script doesn't run:
In the script (indicator) below, I added a thread to detect the process to the indicator:
#!/usr/bin/env python3
import subprocess
import os
import time
import signal
import gi
gi.require_version('Gtk', '3.0')
gi.require_version('AppIndicator3', '0.1')
from gi.repository import Gtk, AppIndicator3, GObject
from threading import Thread
# --- set the path to the script below
script = "/path/to/script.sh"
currpath = os.path.dirname(os.path.realpath(__file__))
def runs(script):
# function to check if the process runs
try:
return subprocess.check_output(["pgrep", "-f", script]).decode("utf-8")
except subprocess.CalledProcessError:
pass
class Indicator():
def __init__(self):
self.app = 'show_proc'
iconpath = currpath+"/nocolor.png"
self.indicator = AppIndicator3.Indicator.new(
self.app, iconpath,
AppIndicator3.IndicatorCategory.OTHER)
self.indicator.set_status(AppIndicator3.IndicatorStatus.ACTIVE)
self.indicator.set_menu(self.create_menu())
self.update = Thread(target=self.check_runs)
# daemonize the thread to make the indicator stopable
self.update.setDaemon(True)
self.update.start()
def check_runs(self):
# the function (thread), checking for the process to run
runs1 = ""
while True:
time.sleep(1)
runs2 = runs(script)
# if there is a change in state, update the icon
if runs1 != runs2:
if runs2:
# set the icon to show
GObject.idle_add(
self.indicator.set_icon,
currpath+"/green.png",
priority=GObject.PRIORITY_DEFAULT
else:
# set the icon to hide
GObject.idle_add(
currpath+"/nocolor.png",
runs1 = runs2
def create_menu(self):
menu = Gtk.Menu()
# quit
item_quit = Gtk.MenuItem('Quit')
item_quit.connect('activate', self.stop)
menu.append(item_quit)
menu.show_all()
return menu
def stop(self, source):
Gtk.main_quit()
Indicator()
GObject.threads_init()
signal.signal(signal.SIGINT, signal.SIG_DFL)
Gtk.main()
show_proc.py In the head section of the script, in the line:
set the path to your script or applications
Copy both icons below (right click -> save as), and save them in one and the same directory as show_proc.py, and exactly named as indicated below
<-- this is a transparent icon, but is is there :). move the cursor over it until the finger appears...
Now test- run show_proc.py by the command:
python3 /path/to/show_proc.py
and start up your script
If all works fine, add the following to sgtartup applications:
/bin/bash -c "sleep 15 && python3 /path/to/show_proc.py"
In Xubuntu, install the Generic Monitor panel plugin by pasting the following in terminal:
sudo apt-get install xfce4-genmon-plugin
From the Generic Monitor plugin page:
"This plugin cyclically spawns the indicated script/program, captures its output (stdout) and displays the resulting string into the panel.
The string can also contain markup to display an image, a bar, a button and a personalized tooltip."
Set the following script to run using the Generic Monitor panel plugin. I recommend without a Label. Be sure to replace your_script with the name of your script and add in the path to your icon.
#!/bin/bash
status=$(pgrep your_script)
if [ -n "$status" ]; then
echo "<img>/path/to/your/icon.png</img>"
else
echo ""
fi
It is interesting that you mention Dropbox. I use this plugin for Dropbox.
There are also plugins for the panel in Unity that show command or script output. However, I just have Xfce so I can't confirm a particular one. I hope all works out great.
