If one of users create a folder, other users have no permission to write into it. How can I solve this problem ?
#======================= Global Settings =======================
[global]
create mask =0777
directory mask = 0777
workgroup = ENERJIK
server string = %h server (Samba, Ubuntu)
   dns proxy = no
#### Debugging/Accounting ####
   log file = /var/log/samba/log.%m
   max log size = 1000
  syslog = 0
  panic action = /usr/share/samba/panic-action %d
####### Authentication #######
   server role = standalone server
   passdb backend = tdbsam
   obey pam restrictions = yes
   unix password sync = yes
   passwd program = /usr/bin/passwd %u
   passwd chat = *Enter\snew\s*\spassword:* %n\n *Retype\snew\s*\spassword:* %n\n
   map to guest = bad user
############ Misc ############
   usershare allow guests = yes
#======================= Share Definitions =======================
 [printers]
   comment = All Printers
   browseable = no
   path = /var/spool/samba
   printable = yes
   guest ok = no
   read only = yes
   create mask = 0700
[print$]
   comment = Printer Drivers
   path = /var/lib/samba/printers
   browseable = yes
   read only = yes
   guest ok = no
[Aylik Denetim Bilgisi]
   comment = Enerjik Yapı Denetim Dosya Paylaşım Alanı
   path = /media/depo/Aylikdenetimbilgisi
   browseable = yes
   write list = emre fatmanur ulfet
   guest ok = no
[Çalışan Takip]
   path = /media/depo/Calisantakip
   browseable = yes
   guest ok = no
[Inşaat Takip]
   path = /media/depo/Insaattakip
   create mask = 0777
   browseable = yes
   guest ok = no
[Ruhsatlı Projeler]
   path = /media/depo/Ruhsatliprojeler
   browseable = yes
   write list = emre murat eren servet nuri
   guest ok = no
[Enerjik]
   path = /media/depo/EnerjikYD
   browseable = yes
   write list = emre ulfet fatmanur
   valid users = emre ulfet fatmanur
   create mask = 0777
   guest ok = no
[c$]
   comment = Kök dizin paylaşımı
   path = /
   browseable = no
   read only = no
   write list = root
Duranthe
create mask only defines the maximum rights a file can be created with. If the windows user creates a file with 0750, that's the right that's going to be applied with your settings, since it's being bitwise ANDed. You probably want to combine your settings with the force (directory) create mode = 0777 setting.
For more info check man 5 smb.conf: https://www.samba.org/samba/docs/man/manpages-3/smb.conf.5.html#CREATEMASK
Jakob Lenfers
  • 1,105
  • 17
I think the reason of problem is user permissions. When I used Active Control List (How do I set up a folder so that anything created in it inherits permissions?), problem has been solved partially. But now if one user create a folder, others cannot delete it but they can write into it.
Duranthe
