I use Guake with tmux as my preferred terminal on Ubuntu 14.04LTS. I would like to be able to run a script from nautilus that does the following actions:
Ctrl + L, Ctrl + C, F12, cd Ctrl + Shift + V
meaning: Open the path I am currently in on nautilus in Guake/tmux.
I followed the instructions that are mentioned in this question and created the following script (called test.sh):
#!/bin/bash
xdotool key Ctrl+L
xdotool key F12
xdotool type cd
xdotool key space
xdotool key Ctrl+Shift+V
and put it in ~/.local/share/nautilus/scripts as indicated here
It works fine when it is put in a directory and run from there.
However, when I run the script from the nautilus menu. it always enters the string
/home/bruni/.local/share/nautilus/scripts/test.sh
irrespective of where I am in Nautilus
PS: The proposed solution does not necessarily have to build on the above path of using xdotool. I am perfectly happy with any solution that would let me open the current nautilus path in guake/tmux (the running shell not a new one).
