Error mounting /dev/sda1 at /media/mdnazmossakib/01D189A576840DF0: Command-line `mount -t "ntfs" -o "uhelper=udisks2,nodev,nosuid,uid=1000,gid=1000,dmask=0077,fmask=0177" "/dev/sda1" "/media/mdnazmossakib/01D189A576840DF0"' exited with non-zero exit status 14: The disk contains an unclean file system (0, 0).
Metadata kept in Windows cache, refused to mount.
Failed to mount '/dev/sda1': Operation not permitted
The NTFS partition is in an unsafe state. Please resume and shutdown
Windows fully (no hibernation or fast restarting), or mount the volume
read-only with the 'ro' mount option.
What is the solution to this? It was working fine, but this suddenly happened. Help me to solve this.
wjandrea
  • 14,504
@Nazmos Sakib. You can, if you are using windows 8 and that you have shutdown your system completely but still facing the same issue.., go to your power settings and ensure that "on shutdown: the machine actually shuts down" and does not hibernate instead. Then after these settings you can shut down and the power on and log into Ubuntu, and access your drive.
ThunderBird
  • 1,963
  • 13
  • 22
  • 31
