During the test of my script.
The cronjob should run a script through the browser every 2 minutes. So I had the following cron:
*/2 * * * * wget -O http://192.10.10.1/mypage/myscript.php
The cron run a couple of times before I changed it to:
0 1 * * * wget -O http://192.10.10.1/mypage/myscript.php
to run the script everyday at 1am but it does not work.
I am a bit confused why the first one successfully run my script while the latter didn't. What am I doing wrong? Or what could possibly be the reason why running it at 1am does not work?
As pointed out in a comment above, the most obvious pbm is that you are not using the -O option correctly.
Look up man wget in terminal. Here is an extract:
-O file
--output-document=file.
The documents will not be written to the appropriate files, but all will be concatenated together and written to "file". If - is used as file, documents will be printed to standard output (stdout), disabling link conversion. Use ./- to print to a file literally named -.
Use of -O is analogous to shell redirection:
wget -O file http://foo is intended to work like wget -O - http://foo > file; where "file" will be truncated immediately, and all downloaded content will be written there.
If, as a non root user, you run a GUI cmd or direct yr output to stdout in an already running X session, make sure yr cron environment knows about the active display. To make cron GUI aware, i.e. to tell it, what display the program should use (:0 is the default in a desktop environment)
0 1 * * * export DISPLAY=:0; XAUTHORITY=~/.Xauthority /usr/bin/wget -O - http://192.10.10.1/mypage/myscript.php
or, if you want to set the DISPLAY environment variable ONLY for a specific cmd:
0 1 * * * DISPLAY=:0 XAUTHORITY=~/.Xauthority /usr/bin/wget -O - http://192.10.10.1/mypage/myscript.php
or, if redirecting output to a file for later perusal, the need to specify the correct display disappears because nothing actually goes to stdout :
0 1 * * *  /usr/bin/wget -O <filename> http://192.10.10.1/mypage/myscript.php
The latter solution makes more sense, if you run yr cron job at 1am and you are not sitting in front of yr desktop display.
Let us known in case of continuing problems.
Cbhihe
  • 2,801
  • 27
  • 47
