I tried to follow the steps listed here https://www.linux.com/blog/wine-1735-released-how-install-ubuntudebianlinux-mint
After adding the PPA and running apt-get update, when I try to install wine with:
sudo apt-get install -y wine1.7
I get this output:
Reading package lists... Done
Building dependency tree
wine1.7 : Depends: wine1.7-amd64 (= 1:1.7.44-0ubuntu1)
          Depends: wine1.7-i386 (= 1:1.7.44-0ubuntu1)
I also read this: Installing Wine on Ubuntu 15.10, but nothing seems to help.
Also, (I don't know if I should mention this in another question or if it is related to the current error I get) I had installed winetricks and it worked without any problem after installing "playonlinux" (I don't know if the problem started BECAUSE I installed playonlinux since I didn't use winetricks for days prior to trying to install playonlinux so the underlying problem may or may not have been created prior to this installation) I couldn't find winetricks on my apps list and right clicking on .exe files would pop winetrickes on "Open with" option...
Last but not least, in /usr/bin/ there is no winetricks executable, only a winetricks shell script.
papajo
  • 3,087
From https://wiki.winehq.org/Ubuntu:
If your system is 64 bit, enable 32 bit architecture (if you haven't already):
sudo dpkg --add-architecture i386
Add the repository:
sudo add-apt-repository ppa:wine/wine-builds
Update the package list:
sudo apt-get update
Then install (example for the development branch):
sudo apt-get install --install-recommends winehq-staging
If you prefer to use the devel (not Staging) branch, replace winehq-staging with winehq-devel in the line above.
If apt-get complains about missing dependencies, install them, then repeat the last two steps (update and install).
To install the latest version of Winetricks (recommended, the version in the repos is old), run:
wget https://raw.githubusercontent.com/Winetricks/winetricks/master/src/winetricks && sudo cp winetricks /usr/bin/ && sudo chmod +x /usr/bin/winetricks
