I noticed that the grid plugin wasn't restoring windows to the original size. So I went to ccsm to try to tweak the options to get the desired results. I tried disabling "snap windows to their original size", to then renable it and see if it worked. However, when I disabled it, the windows lost their title bars, the panel, dash and launcher were gone. I usually run "unity --replace" when this sort of thing happens, but because there was no dash I couldn't run any commands. So I pressed Ctrl+Alt+F6b (not sure what this is callled) and ran "unity --replace" from there. However unity wasn't restored and now I only have a top bar with only the appmenu and no launcher or dash. I tried to logout and reboot but neither worked. Gnome Shell works, though. Please help me, I don't want to reinstall the OS or something to solve this issue.
deox
  • 624
Try running unity --reset from a terminal.
RobinJ
  • 9,020
If you delete the compiz config settings, they will be reset once you log in again. Try executing the following command, one-by-one:
rm -rf $HOME/.compiz-1
rm -rf $HOME/.compiz/
rm -rf $HOME/.config/compiz-1
rm -rf $HOME/.gconf/apps/compiz-1
rm -rf $HOME/.gconf/apps/compizconfig-1
rm -rf $HOME/.cache/compizconfig-1
nanofarad
  • 20,906
