158
I need to use php5 (5.6) because I'm working on a Drupal 7 project which doesn't support php7. The problem is I recently updated to ubuntu 16.04 Xenial which seems to no longer support php5.
I tried to install it from this repo, however when It try to install it with apt I always get similar errors.
$ sudo apt-get install php5-cli
Cependant les paquets suivants le remplacent :
  php7.0-cli:i386 php7.0-cli`
Which means it's obsolete. How can I install PHP 5.6 on Xenial?
Nikolai
  • 1,683
Remove all the stock php packages
List installed php packages with dpkg -l | grep php| awk '{print $2}' |tr "\n" " " then remove unneeded packages with sudo aptitude purge your_packages_here or if you want to directly remove them all use :
sudo apt-get purge `dpkg -l | grep php| awk '{print $2}' |tr "\n" " "`
Add the PPA
sudo add-apt-repository ppa:ondrej/php
If you get add-apt-repository: command not found run the following command first :
sudo apt-get install software-properties-common
Install your PHP Version
sudo apt-get update
sudo apt-get install php5.6
You can install php5.6 modules too for example
sudo apt-get install php5.6-mbstring php5.6-mcrypt php5.6-mysql php5.6-xml
Verify your version
If you have installed php5.6-cli
sudo php -v
If you don't have php5.6-cli, put this on a .php file
<?php
      //outputs php configuration info
      phpinfo();
storm
  • 5,013
15
Run the following commands:
$ sudo apt-get install python-software-properties
$ sudo add-apt-repository ppa:ondrej/php
$ sudo apt-get update
$ sudo apt-get install -y php5.6
Check your PHP Version
php -v
Antonio Nicasio
  • 151
You can even consider using vagrant (or similar technology) to assist in using both versions at the same time. Vagrant is essentially a VM client designed to help spin VM's up and down quickly and easily with project based configuration; i.e. you can configure a VM specifically for a project and each VM can be different per project if need be.
This means that you can develop a project and test it on your local machine using the same production configuration as the project will be run under. Not only is this great for yourself but also means that a team of developers can always test under the same circumstances as the VM configuration is portable and cross-platform (it's just a text file).
Once vagrant and virtual box are installed, it's as easy as running:
vagrant init ubuntu/trusty64; vagrant up --provider virtualbox
and once the vm is up and running you can use:
vagrant ssh
and you can now manually install apache, php and mysql. You can also define a provisioning configuration, so that when you enter:
vagrant up
the VM builds itself as well as installs all the binaries you need and can even do a git clone of your code, setup networking so you can view the application in your browser, etc.
For more detailed information look here: https://www.vagrantup.com/docs/getting-started/
You can use XAMPP Linux.You can download any version of xampp linux from the below mentioned official xampp site.
https://www.apachefriends.org/download.html
Enter downloaded file location using terminal.
First give certain permission for the downloaded binary file. (Assume that i downloaded 64 bit binary package.)
sudo chmod a+x xampp-linux-x64-5.6.23-0-installer.run
Then install the xampp
sudo ./xampp-linux-x64-5.6.23-0-installer.run
If you are download 32 bit binary file do below mentioned like this
sudo chmod a+x xampp-linux-5.6.23-0-installer.run
sudo ./xampp-linux-5.6.23-0-installer.run
