I need to run some application to convert large files (7GB). The converter application isn't nicely written. So it doesn't stream the coverted data. Therefore, it requires high amount of memory. I have 8GB memory and 8GB swap space. But the application reports a memory usage of around 9GB and stops at 60% of conversion. I assume with some more memory, I can finish the task. As this needs to be done once only, I can maybe allocate some space from my SSD to extend memory temporarily. Only for this operation. Is there any way to do that without messing with partitions?
Thanks!
You can indeed use swapfile as temporary addition to your system memory. Personally, I have an SSD and use 1 GB swap file for protection instead of having a partition , since it's a compromise between using the limited disk space, but having extra memory if I ever run out of RAM
First create the file itself
sudo dd if=/dev/zero of=/swapfile bs=1M count=1024
The command will create a file named swapfile inside your root folder, its content being all zeroes and size of 1024 megabytes (1 GB). To make it 2 GB , change count value to 2048
Next, make it read-writable by root only
sudo chmod 600 /swapfile
And format it to swap
sudo mkswap /swapfile
Finally, enable the file
sudo swapon /swapfile
You can disable it at any point using sudo swapoff /swapfile command and remove at will; in addition, since here we don't add it to the /etc/fstab file, it won't be added at next boot, so on the next boot you can remove it
FYI, all this I've turned into a script so that there's an actual single command you can execute to add swap. See How can i increase size of swap file?
