I keep getting the famous sources.list error even after trying to implement the supposed fix.
My next thing is to try to totally remove chrome/chromium and start over. So I followed these removal instructions.
However, now when I do apt-get update, I keep getting the same error. What triggers the error? How can I completely remove chrome or whatever triggers that error?
zkurtz
  • 323
To answer your main question first - for getting rid of the sudo apt-get update error message, you have to remove the Google Chrome repository - open a terminal and execute this command :
sudo rm /etc/apt/sources.list.d/google-chrome.list
To completely remove Chromium and Google Chrome execute :
sudo apt-get purge chromium-browser google-chrome-stable
When you also want to remove the configuration files, delete these folders :
/home/user/.config/chromium and /home/user/.config/google-chrome.
Note : I assume that you have the google-chrome-stable package installed.
Update :
I received an information that there might be another Google .list file in the sources.list.d folder - so in case the error still occurs, check this folder and correct or delete the entries as well.
cl-netbox
  • 31,491
I finally thought of looking around in the /etc/apt/sources.list.d directory to see if there was anything other than chrome/chromium in that is associated with google somehow. Indeed, I found a google.list file. I have no idea how that got there or what program it was associated with, but after deleting it my apt-get update worked cleanly.
zkurtz
  • 323
