There is a warning in my country that this trojan infected computers over a news site (The Trojans name is GOZI).
I used clamav but it says it is not the latest version.
How to install the latest version of clamav?
empedokles
  • 4,023
Uninstall clamav and clamtk repository version:
sudo apt-get purge clamav clamtk
First you will need some dependencies and build tools:
sudo apt-get install openssl build-essential libssl-dev checkinstall
Download this file, it will go to your /home:
wget https://www.clamav.net/downloads/production/clamav-0.99.1.tar.gz
Extract that file and change to the folder it created:
tar -xvzf ~/clamav-0.99.1.tar.gz
cd ~/clamav-0.99.1
Now run the following commands to build clamav 0.99.1:
./configure
make
Now build a package with
sudo checkinstall
checkinstall will guide you through the building of a .deb package and when it is done run
sudo dpkg -i ~/clamav-0.99.1/clamav_0.99.1-1_amd64.deb
Now it is installed but you may face errors about a config file, if you do run these commands (Thanks to user Terrance on this question for this, if you use it give him a vote)
sudo dpkg-reconfigure clamav-freshclam
Just keep pressing Enter to use default settings, then run
sudo rm -f /usr/local/etc/freshclam.conf
sudo ln -s /etc/clamav/freshclam.conf /usr/local/etc/freshclam.conf
Now you can run a
sudo clamscan -r /
To do a scan.
Tested on 15.10.
Mark Kirby
  • 18,949
  • 19
  • 79
  • 116
Excerpt from http://www.govcert.admin.ch/blog/21/20min.ch-malvertising-incident
The infection chain is as follows:
  1. The swf file on 20min.ch contains an embedded Javascript which does a basic fingerprint using User Agent and Cookie. Based on this information a decision is made whether to redirect to the infection site or not.
  2. Redirect to the exploit Kit where a VB Script is downloaded with another check which exploit would suit the target
  3. Infect the device with Gozi in the form of a .dll that is made persistent via registry key (rundll) under HKEY\CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Run. The dll resides in the %APPDATA% folder of the user.
msomm
