Possible Duplicate:
MDADM Superblock Recovery
So I was having a lot of trouble with Ubuntu after upgrading to 11.10. I decided to do a clean install, and things seem to be much better. However, I am unable to get my RAID to mount after installing mdadm. I'm able to go to /media, and then mount it, but it used to mount on boot. Trying to edit fstab, but when I fdisk -l, I'm getting
Disk /dev/md127 doesn't have a valid partition table.
When I made the array, I gave it a .ext4 partition table, and thought it was taken care of. Please help! If I run .ext4 again, I don't want it to erase the data currently on the array.
sudo fdisk -l
WARNING: GPT (GUID Partition Table) detected on '/dev/sda'! The util fdisk doesn't support GPT. Use GNU Parted.
Disk /dev/sda: 80.0 GB, 80025280000 bytes
255 heads, 63 sectors/track, 9729 cylinders, total 156299375 sectors
Units = sectors of 1 * 512 = 512 bytes
Sector size (logical/physical): 512 bytes / 512 bytes
I/O size (minimum/optimal): 512 bytes / 512 bytes
Disk identifier: 0x00000000
Device Boot Start End Blocks Id System
/dev/sda1 1 156299374 78149687 ee GPT
Disk /dev/sdb: 2000.4 GB, 2000398934016 bytes
255 heads, 63 sectors/track, 243201 cylinders, total 3907029168 sectors
Disk identifier: 0x000412f6
/dev/sdb1 63 3907024064 1953512001 fd Linux raid autodetect
Disk /dev/sdc: 2000.4 GB, 2000398934016 bytes
Disk identifier: 0x0005cf54
/dev/sdc1 63 3907024064 1953512001 fd Linux raid autodetect
Disk /dev/sdd: 2000.4 GB, 2000398934016 bytes
Disk identifier: 0x000a563b
/dev/sdd1 63 3907024064 1953512001 fd Linux raid autodetect
Disk /dev/sde: 2000.4 GB, 2000398934016 bytes
Disk identifier: 0x00088e1f
/dev/sde1 63 3907024064 1953512001 fd Linux raid autodetect
Disk /dev/sdf: 2000.4 GB, 2000398934016 bytes
Disk identifier: 0x000a104e
/dev/sdf1 63 3907024064 1953512001 fd Linux raid autodetect
Disk /dev/sdg: 2000.4 GB, 2000398934016 bytes
Disk identifier: 0x000271fa
/dev/sdg1 63 3907024064 1953512001 fd Linux raid autodetect
Disk /dev/md127: 10002.0 GB, 10001973248000 bytes
2 heads, 4 sectors/track, -1853079296 cylinders, total 19535104000 sectors
I/O size (minimum/optimal): 1048576 bytes / 5242880 bytes
Disk /dev/md127 doesn't contain a valid partition table
