Different ways to edit those settings
The settings you mention are stored in the dconf database in ~/.config/dconf (in binary format). This database can either be directly edited with dconf, or via gsettings. The difference is explained at the last section of this answer.
Once you have the information, posted in your question, you can therefore change the corresponding settings in two different ways.
Using your first example (setting remember-recent-files):
using dconf write:
dconf write /org/gnome/desktop/privacy/remember-recent-files false
or
using gsettings set:
gsettings set org.gnome.desktop.privacy remember-recent-files false
Similarly, reading the current setting:
using dconf read:
dconf read /org/gnome/desktop/privacy/remember-recent-files
or
using gsettings get:
gsettings get org.gnome.desktop.privacy remember-recent-files
In the first case, you edit the dconf database directly, in the latter you are using gsettings, which is a CLI frontend to dconf.
Which way to prefer; dconf or gsettings?
To protect the integrity of your dconf database, in general, it is considered better practice to use gsettings.
Frome this link, we read:
The dconf program can perform various operations on a dconf database,
such as reading or writing individual values or entire directories.
This tool operates on dconf directly, without using gsettings schema
information. Therefore, it cannot perform type and consistency checks
on values. The gsettings(1) utility is an alternative if such checks
are needed. You can see gsettings as the cli-frontside to dconf.
Read more on gsettings and dconf.
