I have Ubuntu 14.04.1 . When using the pc (usually watching a video on youtube, or something that requires some cpu) it reboots, and then it usually doesn't restart again, you have to switch off and wait for some minutes, then switch on and it works, what could happend? I checked memories and hard disc and Ubuntu said they were ok. Sorry for my English.
Roque
  • 325
There are things that could cause this, one is heat as others have mentioned, and another is the power supply. Open the side of the pc if this is a desktop, and leave it open. Start up the pc. If it stays on, heat is your issue. Try blowing it out with a blower or another less preferred option is to use the vacuum cleaner to remove dust from the heatsink on the cpu.
If this does not solve the problem replace you Power Supply. The fact that it doesn’t come on for a while after the shutdown is making me suspect static in the power supply.
warhansen
  • 230
sudo apt-get update
sudo apt-get upgrade
sudo init 6
after it restarts see if it is still happening
muru
  • 207,228
