I'm trying to get Webext to work. I read this http://www.linuxintro.org/wiki/Use_WebEx_with_Linux which tells me to check for missing dependencies via ldd *.so | grep "not found"
It gives me this list:
~$ ldd .webex/1524/*.so | grep "not found"
    libgtk-x11-2.0.so.0 => not found
    libgdk-x11-2.0.so.0 => not found
    libXmu.so.6 => not found
    libXtst.so.6 => not found
    libstdc++.so.6 => not found
    libXt.so.6 => not found
    libXi.so.6 => not found
    libjawt.so => not found
    libasound.so.2 => not found
    libuuid.so.1 => not found
But if I try to install these 'missing' dependencies I am informed that they are already at latest version. E.g.
~$ sudo apt-get install libgtk2.0-0
Reading package lists... Done
Building dependency tree
libgtk2.0-0 is already the newest version (2.24.30-1ubuntu1).
0 to upgrade, 0 to newly install, 0 to remove and 0 not to upgrade.
So don't know how to get this going. Anyone have webex working?
Terrance
  • 43,712
6 Answers6
I fixed Desktop Share Webex feature on newly installed 16.04 by this way: https://askubuntu.com/a/363400
but i replaced 'openjdk-7-jre' to 'openjdk-8-jre' and 'icedtea-7-plugin' to 'icedtea-8-plugin'
There are still 'not found' files in the webex directory, and audio calls still does not work, but i don't need it (we use skype)
Yuri Gor
  • 173
I was able to get it working pretty well thanks to Yuri's answer and some of the others here. I thought I could provide some additional details and explicit steps.
First, I'm running Oracle's JDK 8, installed via PPA, on a 64-bit platform. This works to launch the meeting dashboard, but desktop sharing doesn't work, because WebEx uses a 32-bit foundation. So I added the 32-bit architecture:
sudo dpkg --add-architecture i386
sudo apt update
Then I installed the 32-bit packages:
sudo apt install openjdk-8-jre:i386 libxmu6:i386 libpangoxft-1.0-0:i386 libpangox-1.0-0:i386 libxv1:i386
This pulls in a whole bunch of dependencies. After the packages are installed, the WebEx libraries show all dependencies met (except for libjawt.so, which is provided by the JRE):
$ ldd ~/.webex/T30_MC/*.so | grep "not found"
Restart Firefox (I'm not sure if this was strictly necessary, but I wanted to be sure it got all the new libraries). After this, I was able to join my meeting and see the shared desktop. I haven't yet tried audio, as the meeting I was in didn't have web audio enabled.
Mac
  • 211
I think the issue is not the lack of dependencies in Linux, the problem is the WebEx update a couple of weeks ago.
I read in other blog, that new WebEx is not longer supporing JAVA, reason why is not working for us.
I used this approach following by
sudo apt-get update
sudo apt-get upgrade
and restarted firefox.
Severus Tux
  • 10,126
apt-get install openjdk-8-jre:i386
The above command should fix most of the issue, if not all of it. I also did the below to finish it off.
apt-get install libuuid1:i386 libasound2:i386 libxt6:i386 libxmu6:i386
I tried adding the following:
OPTION 1
sudo apt-get -y remove icedtea-7-plugin:i386 icedtea-netx:i386
sudo apt-get -y install openjdk-8-jre:i386 libxmu6:i386 icedtea-8-plugin firefox
sudo update-alternatives --set mozilla-javaplugin.so /usr/lib/jvm/java-8-openjdk-amd64/jre/lib/amd64/IcedTeaPlugin.so
OPTION 2
sudo apt-get update
And now I can open the WebEx just fine, but I am unable to use the audio option, and I cannot see what others are sharing, does anybody knows if this can be fixed in Ubuntu 16.04?
anonymous2
  • 4,325
