W: An error occurred during the signature verification. The repository is not updated and the previous index files will be used. GPG error: http://in.archive.ubuntu.com trusty Release: The following signatures were invalid: BADSIG 16126D3A3E5C1192 Ubuntu Extras Archive Automatic Signing Key <ftpmaster@ubuntu.com>
W: Failed to fetch http://dl.google.com/linux/chrome/deb/dists/stable/Release.gpg  Bad header line [IP: 216.58.197.46 80]"
W: Failed to fetch "http://dl.google.com/linux/chrome/deb/dists/stable/main/binary-amd64/Packages  404  Not Found [IP: 216.58.197.46 80]"
W: Failed to fetch http://in.archive.ubuntu.com/ubuntu/dists/trusty/Release
W: Some index files failed to download. They have been ignored, or old ones used instead.
how to correct this errors
mchid
  • 44,904
  • 102
  • 162
You need to edit your files to point to http:// instead of http//.
First, run the following command to fix your sources.list:
sudo sed -i 's|http/|http:/|g' /etc/apt/sources.list
Then, run the following command to fix your google-chrome.list:
sudo sed -i s|http/|http:/|g' /etc/apt/sources.list.d/google-chrome.list
Finally, run the following command to update apt-get:
sudo apt-get update
mchid
  • 44,904
  • 102
  • 162
