I have some services in my init.d folder for e.g. hdfs, zookeeper, elasticsearch, hbase and so on.
Now, I have added all those services to startup by doing the update-rc.d 'service' defaults command. As we know, hbase can't run if hdfs and zookeeper are not started. So I want to start hdfs first, then zookeeper and then finally hbase.
how do I do this?
update-rc.d(8) enables or disables services, while the ordering of services is handled by insserv(8), and can be customized by editing the LSB header of the service and setting/adding:
Required-Start: $all
In oldest versions, i can do something like this to determine the order:
update-rc.d myservice start 95 2 3 4 5 . stop 70 0 1 6 .
But after Ubuntu 14, i tried this Ubuntu 16.04 (4.4.0-31-generic):
update-rc.d myservice defaults 95 70
And doesn't work, always creates the order defined in the header:
 sudo find /etc/ -name ???myservice | sort
/etc/rc0.d/K01myservice
/etc/rc1.d/K01myservice
/etc/rc2.d/S03myservice
/etc/rc3.d/S03myservice
/etc/rc4.d/S03myservice
/etc/rc5.d/S03myservice
/etc/rc6.d/K01myservice
Also al try:
update-rc.d myservice defaults any_text_wath_you_want lalala
Ands seems like ignores all the text after "defaults". I don“t know wath it do when my installation order, I do not think that orders previously installed services.
-1
You can do it by update-rc.d 'service' defaults number where the number is an integer and the lesser the sequence number, the higher the service in the queue i.e it will be executed before other services with a greater sequence number.
The above command will give the same priority for starting as well as killing the service. You can fine tune it further.
So if you have a service which has a lot of dependencies, you can give it a large sequence number to ensure that all of its dependiencies have booted up before it starts itself.
