I installed KDE indicator through Synaptic Package Manager a couple days ago. Everything works great except for a few times where my device wont show up on PC (solved with a reboot)
I installed the KDE indicator through the terminal. If I launch it normally from menu > preferences, I get nothing. It shows up as a running process in task manager, but no user interface is shown. I can't access/use any of its features. Is there a solution? is it cause KDE-connect came from synaptic and KDE indicator came from apt-get?
I'm running Lubuntu 15.04.
muru
  • 207,228
Same issue on Lubuntu 18.04.
I have managed to send files from my PC to a paired Android devices using the command line utility from kde connect. To see the options available, open up a terminal and type
kdeconnect-cli
Maybe this helps.
zx485
  • 2,865
Same issue on 18.04
I made the KDE Connect show up by sending a file from my phone to my computer. It automatically put the file in Downloads and added the KDE icon to the task bar. enter image description here
