I have constant wi-fi drops with Ubuntu 14.04. I was trying to fix this issue with the following code:
sudo apt-get install --reinstall linux-headers-$(uname -r) linux-headers-generic build-essential dkms git
git clone https://github.com/pvaret/rtl8192cu-fixes.git
sudo dkms add ./rtl8192cu-fixes
sudo dkms install 8192cu/1.9
echo "blacklist rtl8192cu" | sudo tee -a /etc/modprobe.d/blacklist.conf
When I entered the fourth line, sudo dkms install 8192cu/1.9, I got this error:
$ sudo dkms install 8192cu/1.9
Error! Could not find module source directory.
Directory: /usr/src/8192cu-1.9 does not exist.
How can I fix this? What should I do next?
Here is network card info:
$ lspci -nnk | grep -iA2 net; rfkill list all
01:00.0 Network controller [0280]: Qualcomm Atheros QCA9565 / AR9565 Wireless Network Adapter [168c:0036] (rev 01)
Subsystem: Foxconn International, Inc. Device [105b:e068]
Kernel driver in use: ath9k
0: phy0: Wireless LAN
Soft blocked: no
Hard blocked: no
1: acer-wireless: Wireless LAN
Soft blocked: no
Hard blocked: no
4: hci0: Bluetooth
Soft blocked: no
Hard blocked: no
In case it helps, here is the output from the first three commands:
$ sudo apt-get install --reinstall linux-headers-$(uname -r) linux-headers-generic build-essential dkms git
Reading package lists... Done
Building dependency tree
The following NEW packages will be installed:
dkms
0 upgraded, 1 newly installed, 4 reinstalled, 0 to remove and 0 not upgraded.
Need to get 3,401 kB of archives.
After this operation, 351 kB of additional disk space will be used.
Get:1 http://us.archive.ubuntu.com/ubuntu/ trusty/main build-essential amd64 11.6ubuntu6 [4,838 B]
Get:2 http://us.archive.ubuntu.com/ubuntu/ trusty-updates/main dkms all 2.2.0.3-1.1ubuntu5.14.04.5 [65.4 kB]
Get:3 http://us.archive.ubuntu.com/ubuntu/ trusty-updates/main git amd64 1:1.9.1-1ubuntu0.3 [2,586 kB]
Get:4 http://us.archive.ubuntu.com/ubuntu/ trusty-updates/main linux-headers-3.19.0-56-generic amd64 3.19.0-56.62~14.04.1 [743 kB]
Get:5 http://us.archive.ubuntu.com/ubuntu/ trusty-updates/main linux-headers-generic amd64 3.13.0.83.89 [2,232 B]
Fetched 3,401 kB in 10s (321 kB/s)
(Reading database ... 703929 files and directories currently installed.)
Preparing to unpack .../build-essential_11.6ubuntu6_amd64.deb ...
Unpacking build-essential (11.6ubuntu6) over (11.6ubuntu6) ...
Selecting previously unselected package dkms.
Preparing to unpack .../dkms_2.2.0.3-1.1ubuntu5.14.04.5_all.deb ...
Unpacking dkms (2.2.0.3-1.1ubuntu5.14.04.5) ...
Preparing to unpack .../git_1%3a1.9.1-1ubuntu0.3_amd64.deb ...
Unpacking git (1:1.9.1-1ubuntu0.3) over (1:1.9.1-1ubuntu0.3) ...
Preparing to unpack .../linux-headers-3.19.0-56-generic_3.19.0-56.62~14.04.1_amd64.deb ...
Unpacking linux-headers-3.19.0-56-generic (3.19.0-56.62~14.04.1) over (3.19.0-56.62~14.04.1) ...
Preparing to unpack .../linux-headers-generic_3.13.0.83.89_amd64.deb ...
Unpacking linux-headers-generic (3.13.0.83.89) over (3.13.0.83.89) ...
Processing triggers for man-db (2.6.7.1-1ubuntu1) ...
Setting up build-essential (11.6ubuntu6) ...
Setting up dkms (2.2.0.3-1.1ubuntu5.14.04.5) ...
Setting up git (1:1.9.1-1ubuntu0.3) ...
Setting up linux-headers-3.19.0-56-generic (3.19.0-56.62~14.04.1) ...
Examining /etc/kernel/header_postinst.d.
run-parts: executing /etc/kernel/header_postinst.d/dkms 3.19.0-56-generic /boot/vmlinuz-3.19.0-56-generic
Setting up linux-headers-generic (3.13.0.83.89) ...
$ git clone https://github.com/pvaret/rtl8192cu-fixes.git
Cloning into 'rtl8192cu-fixes'...
remote: Counting objects: 435, done.
remote: Total 435 (delta 0), reused 0 (delta 0), pack-reused 435
Receiving objects: 100% (435/435), 1.80 MiB | 251.00 KiB/s, done.
Resolving deltas: 100% (222/222), done.
Checking connectivity... done.
$ sudo dkms add ./rtl8192cu-fixes
Creating symlink /var/lib/dkms/8192cu/1.10/source ->
/usr/src/8192cu-1.10
DKMS: add completed.
