here is the biggest problem with Ubuntu for me: make WOT playable under Ubuntu with only Wine, with good performance.
I made a lot of research and finaly i found the solution in some world of tanks forum, here is the way in the response below to definitly play without bug to World Of Tanks on Ubuntu 14.04 LTS (tested in many Ubuntu 14 computer, and in Ubuntu 15 too)
Ugo Hed
  • 679
1, first, of course, download the WoT_internet_install_eu.exe of installation: http://worldoftanks.eu/en/update anywhere you want.
2, open a terminal, and install wine and wintricks if you havn't alreaydy:
sudo apt-add-repository ppa:ubuntu-wine/ppa
sudo apt-get update
sudo apt-get install wine1.5 wine-gecko1.5 wine-mono0.0.8 winetricks
3, then install Ie7:
winetricks ie7
now run
wine 'C:\Program Files\Internet Explorer\iexplore'
4, here is the magic line for wine:
winetricks d3dx9_36 d3dx9_43 vcrun2008 msxml3 wininet corefonts ie7 d3dcompiler_43
NOTE: it will open ie7 and nautilus, you have to:
5, then you have to use the Useful Registry Keys of wine
wine regedit
This will open the registry key of wine, then do this step:
  • On the left, open HKEY_CURRENT_USER, then open Software
  • Right click on Wine -> New -> Key (name it Direct3D)
  • Right click on Direct3D -> New -> String Value (name it VideoMemorySize, double click on it and set 1024 into his value data
Finaly,
wineboot ; pulseaudio -k
6, Here it is ! You can now right click in your WoT_internet_install_eu.exe -> open with -> Wine and install it !
6.1, OR if you already have world of tanks installed completly in your window and if you can acces to the Window Volume, then simply go find the WorldOfTanks.exe and execute it (but your WoTLauncher.exe will be laggy
source: http://forum.worldoftanks.eu/index.php?/topic/218192-how-torunning-wot-under-ubuntu-and-any-linux-perfect-way/
Ugo Hed
  • 679
