I've recently bought a Toshiba Satellite C655. It came with Windows 7 preinstalled. I've never had a notebook before, but as a desktop user, I was a Ubuntu user since 2 years, and I've never had a problem with drivers, wifi, etc.
When I tried to install the Ubuntu 10.04, and also the new and fresh 10.10, in my new laptop, I experienced some troubles with some of the componentes of my computer. For example, I was not able to activate my wi-fi card, although I know the kernel recognizes it correctly, because when doing "lspci" at the terminal, it was listed.
Anyhow, I'm not able to "activate" the wifi, or whatever it's necessary to do in order to be able to search for public networks available, and to connect with them.
The wifi-card the laptops brings is the (the lspci output):
03:00.0 Network Controller: Atheros Communications Inc. AR9285 Wireless Network Adapter (PCI-Express) [168c:002b] (rev 01).
It's anything in you can help me? Thanks a lot in advance!
Edit
Neither solution seems to work. In first place, i've tried installig what hhlp told me. After the installation, nothing seems to change: on right-clicking the wireless icon, it seems to recognize the card, because the option "Enable wifi" was ticked. But, once again, i was not able to "turn the wi-fi" on.
In second place, i didn't try installing the drives, because the card is already recongnized. The issue is that i cannot seem to turn it on!
One thing i've probably missed is that the Toshiba cames with a windows sofntware that allows you to enable / disable the wifi tools. So, it does not have an external "button" to turn it off. I don't know if that's the problem, but i have the feeling that the issue may be aroud there: in how to turn ON the wifi-signal (or to verify if it's on or off) in my ubuntu.
Bruno Pereira
  • 74,715
user4106
  • 141
you have a ath9k
ath9k is a completely FOSS wireless driver for all Atheros IEEE 802.11n PCI/PCI-Express and AHB WLAN based chipsets.
AR9002:
*      AR9220 (>= 2.6.27, an AR9280 card over PCI)
*      AR9280 (>= 2.6.27)
*      AR9281 (>= 2.6.27)
*      AR9285 (>= 2.6.29)
*      AR9287 (>= 2.6.32)
have you tried install this :
sudo apt-get install linux-backports-modules-wireless-maverick-generic
Mark Kirby
  • 18,949
  • 19
  • 79
  • 116
hhlp
  • 42,872
https://help.ubuntu.com/community/WifiDocs/Device/Atheros/AR9285
I use the Release Candidate 5 (nov 2010) in my time and it works.
No need to know about the wifi button it mention, or any wifi utility on windows.
It work I use Ubuntu 10.10 32 bit.
You could try this https://help.ubuntu.com/community/WifiDocs/Device/Atheros/AR9285
Nachito
  • 446
