I've burnt Ubuntu 14.04.4 LTS 64-bit on DVD-R by Infra Recorder, and created a live USB of 15.10 64-bit using Universal USB Installer.
Then I tried installing Ubuntu 14.04.4 LTS 64-bit, or Ubuntu 15.10 64-bit alongside windows 10, but I keep getting these errors:
With no parameter nomodeset (transcribed from video given in original post):
[  0.033675] Ignoring BGRT: Invalid status 0 (expected 1)
[  3.205412] nouveau E[ PGRAPH][0000:01:00.0] failed to load fuc409c
[  3.211068] nouveau E[  PFIFO][0000:01:00.0] unsupported engines 0x00000001
[  3.211138] nouveau E[    DRM] failed to create kernel channel, -22
[ 34.856110] ata8.00: exception Emask 0x52 SAct 0x0 SErr 0xffffffff action 0xe frozen
[ 34.856130] ata8: SError: { RecovComm UnrecovData Persist Proto HostInt PHYRdyChg PHYInt CommWake 10B8B Dispar BadCRC Handshk LinkSeq TrStaTrns UnrecFIS DevExch }
[ 34.856164] ata8.00: failed command:IDENTIFY PACKET DEVICE
[ 34.856178] ata8.00: cmd a1/00:01:00:00:00/00:00:00:00:00/00 tag 2 pio 512 in
[ 34.856178]          res 40/00:03:00:00:00/00:00:00:00:00/a0 Emask 0x56 (ATA bus error)
[ 34.856209] ata8.00: status: { DRDY }
With parameter nouveau.modeset=0 or nomodeset: (transcribed from video:
My PC specs:
  • MOBO: Asus Z97-Pro
  • CPU: Intel i7 4790K
  • GPU: Asus GTX970 Strix
Kacper
You should try to use nouveau.modeset=0 instead nomodeset.
The issue that you have is a kind of incompatibility between nouveau open source driver and some Nvidia graphic cards.
I've got the same problem with a PC with a Nvidia GTX950M: nomodeset didn't work, but nouveau.modeset=0 worked.
P.S. once you have installed Ubuntu, to keep things working, you have to add nouveau.modeset=0 to grub configuration file or blacklist nouveau driver.
My solution that solved my problem:
change grub configuration file opening it as administrator:
sudo nano /etc/default/grub
add nouveau.modeset=0 to the following line as showed:
GRUB_CMDLINE_LINUX_DEFAULT="quiet splash nouveau.modeset=0"
then save with ctrl+o and exit with ctrl-x. Now you have to update grub with the following command:
sudo update-grub
I hope to be useful.
Danibix
  • 2,185
Solution: I had to switch slots.
muru
  • 207,228
Kacper
I had the same problem, for solution your problem must install the last distro of ubuntu, NO 14.04, i dont know why, but didn't recognise the new root of folders than use windows 10, so the partition didn't know where is the point of start on the disc for install ubuntu on 14.04, i believe than the wizard install of 14.04 were a deprecated script, so when u install from a usb or from a disc already u make a copy from the iso of 14.04 a script before from the release of windows 10. obviously that script did not have support for that NEW OS
