33
I have a Lenovo ThinkPad t460s here. It is the NVMe PCI SSD version. The CPU is i7 6600U (Skylake 6th generation) with Intel HD 520.
About a month ago (beginning March 2016), I installed Ubuntu GNOME 16.04 Beta 1. Everything, besides the known issues (Touchpad Physical Button Problems, Lid Close Problems) seemed to work fine.
At this time, I was using the kernel version 4.4.0-7. A few days later, there were several kernel updates (4.4.0-12, 4.4.0-14 and 4.4.0-15). Suddenly, I was experiencing screen flickering. It was really ugly, and I couldn't work anymore. So, I did downgrade the kernel version to 4.4.0-7 and put it on hold (via apt-mark hold). The screen flickering disappeared. Now, I have some graphic artifacts when browsing (firefox, chromium). I think I managed to get rid of these by disabling "smooth scrolling" options.
Is anyone else experiencing similar issues? Or has anyone already found a solution to this problem?
PS: I was installing Ubuntu GNOME 16.04 Final Beta a few days ago and get to try kernel version 4.4.0-16, which has solved the issue with the physical buttons of the touchpad. But unfortunately, the Screen Flickering was not solved. So, I went back to kernel version 4.4.0-7, as described above, again.
18 Answers18
28
@brianjcohen led me in the right direction. The Bug report on chromium had some good discussions on some background on the issue, but apparently it's somewhat of an x.org issue with Intel driver options. You can reference it here if you'd like:
https://bugs.chromium.org/p/chromium/issues/detail?id=606152#c63
To fix it, create or edit the file at /usr/share/X11/xorg.conf.d/20-intel.conf as root with the following:
Section "Device"
    Identifier "Intel Graphics"
    Driver "intel"
    Option "AccelMethod" "sna"
    Option "TearFree" "true"
    Option "DRI" "3"
EndSection
  • From the discussion, the AccelMethod should by default be sna, but apparently not explicitly setting it as such could cause X to crash. sna is definitely faster than downgrading it to uxa.
  • TearFree helps prevent tears in video rendering
  • DRI is a method on how the driver renders things, I think this was the key option. You can find out a whole bunch on what it is here: https://en.wikipedia.org/wiki/Direct_Rendering_Infrastructure#DRI3
  • You can also read the man page at man 4 intel
basicdays
  • 381
UPDATE: Yesterday, I freshly installed Ubuntu GNOME 16.04. It came with an up to date kernel version: 4.4.0-18. It seems to have solved the Screen Flickering issue for me (at least until now). Aditionally, the physical buttons of the touchpad work as intended (i.e. scrolling and drag & drop are working). There seems to be some Screen Tearing in web browsers (firefox and chromium). But it really is not comparable to the Screen Flickering issue before. In firefox, I managed to get rid off the Screen Tearing by disabling "smooth scrolling" option. Unfortunately, the same procedure doesn't seem to help in chromium.
I had this issue on my new Lenovo X1 Carbon running stock 16.04 (4.4.0-33 kernel, Skylake GT2 graphics). I tried two of the answers above (basicdays and Mike O'Connell's) but neither worked. The former caused the graphics to be unusably slow; the latter failed to initialise the graphics at all.
In the end I solved the problem by the other method mentioned here, that is: I removed the problematic Intel-specific graphics driver. All seems good so far - no flickering in Chrome and some glitchy behaviour in other apps seems to have gone away too.
In short, run this and then reboot and all should be good:
sudo apt-get purge xserver-xorg-video-intel
rog
  • 61
Try:
Switching the intel driver from SNA to UXA helped me quite a bit (on a dell skylake here).
Section "Device"
   Driver      "intel"
   Option      "AccelMethod"  "uxa"
EndSection
Add this to xorg config by adding to a file in /usr/share/X11/xorg.conf.d
An user from reddit reported that kernel 4.6.0-994-generic from the Intel DRM branch ( http://kernel.ubuntu.com/~kernel-ppa/mainline/drm-intel-nightly/current/ ) fixed his screen flickering.
I'm not 100% certain this is the same issue everyone else is having. But the issue I had (Lenovo T460s, Skylake running 16.04) was that I would experience single-frame flickering and occasional tearing in Google Chrome, especially if video or animated effects were on the page. The problem was not reproducible in Firefox. I was able to resolve the issue by starting Chrome with --disable-gpu-driver-bug-workarounds --enable-native-gpu-memory-buffers, followed by resetting all experimental flags to default by going to chrome://flags. The explanation, I believe, is that by default (and I'm not sure if this is Ubuntu-specific or not) there are, as the flag implies, workarounds to known GPU bugs enabled, and I think these workarounds are no longer necessary and are actually counterproductive.
More info here: https://bugs.chromium.org/p/chromium/issues/detail?id=606152
To add these startup switches to my Chrome launcher I did the following:
  1. Open the Dash and type 'chrome'.
  2. Drag the Chrome icon to any folder (I used my home folder)
  3. Right click the icon in my home folder and click Properties
  4. In the Command box, add the switches after "%U".
  5. Drag the Chrome icon to my launcher to lock it there.
Edit: I'm running 4.4.0-22.39, and I have not tried this on any other kernel releases.
I did find the following kernel boot parameters to try since they affect screen flicker after trying some of the noted Xorg fixes (either):
  • Disable RC6 sleep modes: i915.enable_rc6=0 OR
  • Disable Panel Self Refresh i915.enable_psr=0
More information here .
To add these, create and edit /etc/modprobe.d/i915.conf with
options i915.preliminary_hw_support=1 i915.enable_psr=0
or try
options i915.preliminary_hw_support=1 i915.enable_rc6=0
I then restarted to make use of these new module options and tested for flicker by sleep/wake cycles. None seemed to help. As for 16.10, the i915.preliminary_hw_support=1 portion may not be necessary.
m1st0
  • 109
I had the same problem an I ended up disabling tlp in /etc/default/tlp. changing TLP_ENABLE=1 to TLP_ENABLE=0.
It looks like power management causes the flickering.
this solution may affect your battery life.
storm
  • 5,013
Here's what I had to do to eliminate screen tearing and flickering in my Ubuntu 16.04:
sudo apt-get install xserver-xorg-video-intel libva-intel-vaapi-driver
Create and edit ~/.drirc:
<device screen="0" driver="dri2">
    <application name="Default">
    <option name="vblank_mode" value="0"/>
    </application>
 </device>
Create and edit /usr/share/X11/xorg.conf.d/20-intel.conf:
Section "Device"
  Driver     "intel"
  Option     "DRI" "3"
EndSection
The above almost does the trick. However, there is a persistent Kernel bug in recent Kernel versions (up from 4.0 until the latest 4.8), which produces flickering exactly like in this video: https://www.youtube.com/watch?v=TqAljJ0U5Pc.
However, if you use a really old kernel the flickering stops.
Download and install an old kernel:
wget http://kernel.ubuntu.com/~kernel-ppa/mainline/v3.13.11.11-trusty/linux-image-3.13.11-03131111-generic_3.13.11-03131111.201411111336_amd64.deb
wget http://kernel.ubuntu.com/~kernel-ppa/mainline/v3.13.11.11-trusty/linux-headers-3.13.11-03131111_3.13.11-03131111.201411111336_all.deb
wget http://kernel.ubuntu.com/~kernel-ppa/mainline/v3.13.11.11-trusty/linux-headers-3.13.11-03131111-generic_3.13.11-03131111.201411111336_amd64.deb
sudo dpkg -i linux-headers-3.13.11-03131111_3.13.11-03131111.201411111336_all.deb linux-headers-3.13.11-03131111-generic_3.13.11-03131111.201411111336_amd64.deb linux-image-3.13.11-03131111-generic_3.13.11-03131111.201411111336_amd64.deb
Last thing to do is to make the above kernel the default one.
Edit /etc/default/grub and change/add the following line:
GRUB_DEFAULT="Advanced options for Ubuntu>Ubuntu, with Linux 3.13.11-03131111-generic"
And finally, update grub:
sudo update-grub
I also had the same problem on a Lenovo Yoga 2 Pro running 16.04 + Gnome Shell.
Video: https://www.youtube.com/watch?v=j_NNn1S_nX8
The screen flashing would occur after 10 minutes sometimes, or 2 hours other times. It would stop while the mouse was moving, and I was able to temporarily stop it for maybe an hour or so by switching consoles via ctrl-alt-f1. I've tried everything in this thread with no success, however I came across a bug report which mentioned changing kernels to 4.4.0-040400. I'm 12 hours in since the kernel downgrade from 4.6, and the flickering is gone!
This is the kernel I used. Simply install these, and uninstall the old kernel. http://kernel.ubuntu.com/~kernel-ppa/mainline/v4.4-wily/
For anyone else having similar problems with more recent installs;
I'm running a fresh 20.04 LTS (ubuntu unity remix) on ThinkPad x260 (skylake i7-6500U / GT2 HD graphics 520) - 5.4.0-31-generic kernel.
Symptoms typically involved titlebars of inactive windows flickering when the mouse was moving, or seemingly if the gpu was being called to redraw the screen content. Worst case scenario was watching a video, switching it to fullscreen, then switching it back to smaller fraction of the display. This would cause all the area outside of the still playing video to flicker intensely.
No solutions worked, from attempting to disable compositor to disabling hardware acceleration etc. until I tried basicdays answer. https://askubuntu.com/a/796808/711096
This cleared it up after a reboot and have not seen a single graphical glitch since, nor any loss of performance at all. I would have left a comment on the answer to just state how this was working with 20.04 LTS in my case and my hardware, but I do not have the required rep.
osbert
kernel 4.6.0-994-generic, from the link posted by Massimiliano fixed the problem for me.
I have an Acer Chromebook with a i5-5200U processor. The symptom was hat I was getting flicker when first booted up the laptop. I would have to close and open the lid a few times to fix the problem.
Since I installed 4.6.0-994-generic it works OK.
Alfy
I have just upgraded to 16.04 from 15.10 on a Dell inspiron 3000 with nvidia geforce graphics. There was very annoying flickering. The thing that fixed it for me was to change the default screen brightness. Brighter or lower fixed it. Going back to the default level brought the flickering back.
Glen
I had the same Problem on a XPS 13 9350. (Kernel 4.4.0-22-generic) I dont now what the Problem is. I think It starts after installing Skype?! It was not flickering after installing ubuntu. it starts a few days later and i think it starts after installing skype? But I´m not sure ;-(
installing the latest kernel (4.6.0-040600-generic) fixed the Problem.
here is a easy way to install the latest kernel version: https://www.youtube.com/watch?v=CokrHUykkUQ
thanks by Massimiliano he brings the best tip!!!
timbo
I was facing the same problem here with my Dell XPS13 Intel® HD Graphics 520 (Skylake GT2). I'm running Ubuntu 16.04 Xenial and I just solved this problem in System Settings -> Software & Updates -> Additional Drivers, enabling the ' Using Processor microcode firmware for intel CPUs from intel-microcode(proprietary)' and then reboot. Hope it works for you as well!
Is it the one with the black lines? I have got that same issue on my samsung ultrabook, it only happens at full "1080P" resolution on my hdmi port. i've observed that this seems to happen most if the screen is really bright, mainly if there is a white background like in "Files or a web browser" but it seems its not really affected by gpu intensive apps like "playing 1080p movies" only the color or brightness sets it seems to set it off?
its not a fix but its a workaround until they release an update that fixes the issue.
Setting the resolution one down from full 1080p seems to stop it, you could try that if you still having issues :)
EDIT: Also try the kernel 4.8.10 This is the "only" kernel that permanently fix the black lines at 1080P for me with an intel HD4000 HDMI output, all other releases seem to have undone that fix from that one on, even 4.9 doesn't fix it. Use the ubuntu kernel update utility to give it a shot "Ukuu" i think its called?
Have had the same problem testing Mint 18 on Samsung 9, i7-6500u.
Consistent with the poster above who solved it by turning off tlp, I found the flickering only occurs when I use powertop to select:
"Autosuspend for unknown USB device 1-5 (8087:0a2b)
from "bad" to "good", i.e. turning on this autosuspend with "good" causes flickering, "bad" does not.
With this left to "bad" my display is stable.
I had a similar problem, and reached this thread seeking a solution.
While upgrading the kernel to 4.8 improved the situation, what solved it for me was installing Intel Graphics for Linux drivers:
https://01.org/linuxgraphics/downloads
Note that for Ubuntu 16.04, you need v2.0.2 and not the latest (currently v2.0.3)
https://01.org/linuxgraphics/downloads/intel-graphics-update-tool-linux-os-v2.0.2
