I would like to create an encrypted login password for a new user while using the useradd command in the CLI. I know that using option -p will allow me to create a password, but using this option does not encrypt the password. I also know that I can create an encrypted password using the passwd [username] command separately after the new user has been created through useradd, but like I said, I would like to know how to create an encrypted password through the useradd command.
You could skip the whole administrator-created-password user administration hassle by creating the userid, then using passwd --expire on it. From man passwd:
-e, --expire
Immediately expire an account's password. This in effect can force
a user to change his/her password at the user's next login.
- 37,856
You could use Perl:
perl -e "print crypt(\"foo\", \"\$6\$$(</dev/urandom tr -dc 'a-zA-Z0-9' | head -c 32)\$\")"
Or Python with the crypt module:
python -c "import crypt; print crypt.crypt(\"foo\", \"\$6\$$(</dev/urandom tr -dc 'a-zA-Z0-9' | head -c 32)\$\")"
foo: the password to encrypt$6: the encryption type, in this case SHA-512$(</dev/urandom tr -dc 'a-zA-Z0-9' | head -c 32): the encryption salt, in this case a random 32 character string.
In conjunction with useradd:
useradd [...] -p"$(perl -e "print crypt(\"foo\", \"\$6\$$(</dev/urandom tr -dc 'a-zA-Z0-9' | head -c 32)\$\")")" [...]
Or:
useradd [...] -p"$(python -c "import crypt; print crypt.crypt(\"foo\", \"\$6\$$(</dev/urandom tr -dc 'a-zA-Z0-9' | head -c 32)\$\")")" [...]
- 41,268
You can use "useradd -p ENCRYPTED-passwd", you need the whole password, including the definition of encryption type, and you need to escape any and all $'s, other than that it seems to works fine.
Simply create a random, disposable user, set their password to what you want to use, then copy their password from the shadow file, copy everything from the first to the second ":" in the shadow file, and use that after the -p.
- 51
You could use openssl like so:
encrypted=`echo $password | openssl passwd -6 -stdin`
For security reasons, you may also want to clear the variable's value asap:
password=
Although I don't think that changes much of anything.
Finally use the encrypted variable on the useradd command line:
... --password "$encrypted" ...
- 2,787
Since passwd does not support --stdin in Ubuntu you could try this:
perl -e "print crypt('password','sa');"
see https://administratosphere.wordpress.com/2011/06/16/generating-passwords-using-crypt3/
- 11
The following worked for me w/Ubuntu 18.04 LTS:
echo 'your_password' > /tmp/pw.txt
pw="$(makepasswd --crypt-md5 --clearfrom=/tmp/pw.txt)"
sudo useradd -p "${pw}" your_username
rm -f /tmp/pw.txt
This may first require installing makepasswd using (on Ubuntu or Debian; google for other distros):
sudo apt install makepasswd
- 153
The command to make a password encrypted is 'mkpasswd'.
With the password of "PASSWORD" you would run 'mkpasswd PASSWORD'.
useradd --password "$(mkpasswd PASSWORD)" <other flags and username here>
- 101
