I have Toshiba pc that came with Windows 8, later updated to Windows 8.1 Had Ubuntu 14.04 installed on it fully replacing Windows. Now I want to give my pc to my brother and he wants Windows back. I uninstalled Ubuntu and now can use only live Ubuntu disc. If I do not use it it symphysis goes into black screen and Gnu Grub version 2.02 beta2-9ubuntu1.3 Grub> I don't have a recovery disc. I tried: - win 10 iso and win7 iso from boot menu Doesn't load. Help
H N
You have to create a Windows DVD with those .iso files you have. On Startup of your PC you should be able to get to the boot menu where you can select the DVD drive to load and install Windows again.
MFS
Did you extract iso files?
If yes, I think doesn't load because they are not set as bootable files. If you can, make a bootable usb stick on a windows PC and then connect it to your computer and select in boot menu USB. You can use Rufus for example. See this link for tutorial. Or if you can use only ubuntu live cd, try this to make a bootable usb on it.
If not, extract to the CD, it should work.
Ragu21
