Desired Behaviour:
I'm setting up a Windows machine next to my Linux machine as a client needs me to use some Windows specific software.
I need to copy a bunch of folders from Linux to Windows 10.
I'm trying to use WinSCP to achieve this, and these are the things I think I need:
IP Address:
ifconfig on Linux machine returns inet addr: 192.xxx.x.x
Whilst googling 'whats my ip' on Linux machine returns 118.xxx.xx.xx
Q01: Which one do I use?
Protocol and Port Number:
Q02: SCP and 22?
Username and Password:
Q03: Do I just use the username and password I usually use to login to my Linux machine?
...A lot of the tutorials I've come across talk about connecting to a Linux computer as a virtual machine, or server, and therefore I'm wondering if I need something to be 'running' on the Linux machine for this to work?
So, last questions:
Q04: Does something need to be running on Linux?
Q05: How do I define which folders will be 'browsable' on the Linux Machine?
What I've Tried:
My last attempt in WinSCP used these credentials:
  • Protocol: SCP
  • Port: 22
  • Hostname: [the inet addr ip from ifconfig]
  • Username: [my normal Linux login username]
  • Password: [my normal Linux login password]
And gave me this error:
Network error: Connection to "192.xxx.x.x" refused.
(Help page for that error)
Edit:
The answer below is more comprehensive, but as a follow up:
I did this on Linux machine:
sudo service ssh start
And got this:
ssh: unrecognised service
So, I had to do this:
sudo apt-get purge openssh-server
sudo apt-get install openssh-server
And then start with:
sudo service ssh restart
And then I used credentials in WinSCP as stated in original post and it worked.
David Foerster
  • 36,890
  • 56
  • 97
  • 151
user1063287
  • 2,255
Question 1:
The second one: 118.xxx.xx.xx - this is your public IP address (although if both computers are on the same network - you may use any of them)
Question 2:
Yes (unless you change it). 22 is the default port for SSH (apparently - SCP too, since it uses SSH for connections). However, many change it to something else to avoid attacks.
Question 3:
Yes.
Question 4:
sshd - the SSH daemon.
  1. Install openssh-server.
  2. Copy the existing /etc/ssh/sshd_config to a backup.
  3. Edit the (non-backup) /etc/ssh/sshd_config
  4. For security, you may want to change Port 22 in the above file to a higher number (2020, for example)
  5. Save.
  6. Allow the port in the firewall - sudo ufw allow {port number}.
  7. Start sshd - sudo service ssh start
Now you can access your computer's files using {port number you chose}
Question 5:
You'll need to use a chroot jail - see this.
