I guess it's also a matter of personal taste, but since I'm starting with a fresh 10.10 install I thought maybe this time I'll keep my system more organized.
What is/are the conventional place(s) to store software and applications?
I have some stuff I get using git (e.g. bioperl), there are some apps I simply download and extract to some place (e.g. eclipse) and obviously I install software using apt-get.
Where is the conventional place to put all of these?
8128
  • 28,868
David B
  • 11,602
The traditional places to install additional software is either /opt or usr/local See also the other similar question
txwikinger
  • 29,406
For software installed via package management you do not need to care where it is installed, you will only manage it with some package management software like apt-get, aptitude or synaptic anyway.
The usual places are, as already mentioned by txwikinger, /opt and /usr/local. I would generally put software that I compile myself into /usr/local, as that has the usual directory structure (bin, lib, ...) already in place. Big software that expects a directory of its own I install into /opt, I think that is the original intent of that folder.
I'm also using a folder for small, self-contained applications in my home folder for some apps, mainly because my home folder is on a seperate partition that I keep when reinstalling the system. So I don't have to install those applications again.
like everyone else said, the package manager will put things where it needs them to be put.
I tend to have a projects/ folder where I checkout my random git projects.
Eclipse likes to keep its projects in workspace/ Depending on how much development I do under eclipse I would do something like $HOME/workspaces/{AndroidStuff, CrazyRandomIdeas} depending on if the things I'm working on should be in its own workspace or is a small project.
Also, occasionally I like to install things in my $HOME since i'm just playing with things and don't want to pollute my filesystem, which I tend to put in $HOME/local. Again this is just my style.. but I end up with
 $HOME/
      bin/  -->symlinks to binaries I installed locally and added to $PATH
      local/  --> local installs of applications, libs etc.
      projects/  --> git check/svn checkouts etc of random code.
      workspace/ --> eclipse stuff.
Try not to install anything in your root filesystem (/) unless you package it. It's a royal pain to uninstall things, (there's always a make install but rarely do you ever get a make uninstall). Also, that's the entire point of a packaging system, to keep track of your programs, files, configs, etc.
csgeek
  • 321
