I've been Googling like a maniac trying to find an answer, so I've now decided to ask here.
How do I go about changing the background of the login screen? (lightdm-gtk-greeter).
It currently uses whatever background I set as desktop background, and doesn't listen to any configuration in the /etc/lightdm/lightdm-gtk-greeter.conf, this is what it's currently set to:
[greeter]
background=/home/illidan/Pictures/bg.png
muru
  • 207,228
realsub
  • 88
Method 1: Assuming you're running <=14.0.4,
sudo su
xhost +SI:localuser:lightdm
su lightdm -s /bin/bash
gsettings set com.canonical.unity-greeter draw-user-backgrounds 'true'
gsettings set com.canonical.unity-greeter background 'path-to-image'
Worked for me. Also, you might need to chmod 644 your background.
Method 2
Copy the picture file to this location
/usr/share/backgrounds/
(The image must be a PNG obviously)
I use Nautilus to navigate to wallpaper file and then invoke a custom script to set the login screen and lock screen background simultaneously:
#!/bin/bash
## Set login wallpaper
# strip new line char passed by Nautilus
FILENAME=$(echo $NAUTILUS_SCRIPT_SELECTED_FILE_PATHS | sed -e 's/\r//g')
# Multiple files can't be selected.
LINE_COUNT=$(wc -l <<< "$NAUTILUS_SCRIPT_SELECTED_FILE_PATHS")
LINE_COUNT=$((LINE_COUNT-1))
if [[ $LINE_COUNT > 1 ]] ; then
    zenity --error --text "Ony one file can be selected at a time! "
    exit 1
fi
# Object type must be "file..." (ie no directories, etc.)
if [ -d "${FILENAME}" ] ; then
    zenity --error --text "$FILENAME is a directory!";
    exit 1
else
    if [ -f "${FILENAME}" ]; then
        : # Bash noop
    else
        zenity --error --text "${FILENAME} is not a file!";
        exit 2
    fi
fi
# Build working file in /tmp
echo "[com.canonical.unity-greeter]" > /tmp/set-login-wallpaper.tmp
echo "draw-user-backgrounds=false" >> /tmp/set-login-wallpaper.tmp
echo "background='$FILENAME'" >> /tmp/set-login-wallpaper.tmp
# Must run as sudo
if [ "$EUID" -ne 0 ] ; then
    # Get sudo password
    PASSWORD=$(zenity --password --title="Set Login Wallpaper" --timeout=20)
    # copy working file to real file using sudo
    echo $PASSWORD | sudo -S cp /tmp/set-login-wallpaper.tmp \
/usr/share/glib-2.0/schemas/10_unity_greeter_background.gschema.override
    # compile using sudo
    echo $PASSWORD | sudo -S glib-compile-schemas /usr/share/glib-2.0/schemas
else
    # Already sudo so simply copy and compile
    # compile
fi
exit 0
Full answer including how to add a script to Nautilus: How to change the Unity lockscreen wallpaper?
