Problem: backuppc is missing essential menu items in its web interface. Items "Edit Hosts", "Edit Config" etc are missing.
backuppc is installed on Ubuntu 14.04.4 LTS. I have even completely removed the backuppc application (using dpkg --purge backupppc), and re-installed it (apt-get install backuppc). Menu items are still missing.
link-to-screenshot
When running /usr/lib/backuppc/cgi-bin/index.cgi directly in the CLI, I do get the missing menu items. The HTML output from index.cgi includes:
<a href="?action=editConfig">Edit Config</a>
<a href="?action=editConfig&amp;newMenu=hosts">Edit Hosts</a>
I tried running de index.cgi on command line as root, backuppc and www-data, all having the same output. (I had to enable a login shell for www-data)
However, that is missing when accessing the backuppc admin from the console in the browser.
The file /etc/backuppc/config.pl contains:
$Conf{CgiAdminUserGroup} = 'backuppc';
$Conf{CgiAdminUsers}     = 'backuppc';
When I change $Conf{CgiAdminUsers} to '*' instead of 'backuppc', it works, but I prefer not to give admin access to all users, so this can only serve as a temporarily workaround.
apache configuration is default by installing backuppc package:
<Directory /usr/share/backuppc/cgi-bin/>
        AllowOverride None
        Allow from all
        Options ExecCGI FollowSymlinks
        AddHandler cgi-script .cgi
        DirectoryIndex index.cgi
        AuthUserFile /etc/backuppc/htpasswd
        AuthType basic
        AuthName "BackupPC admin"
        require valid-user
</Directory>
The contents above are in /etc/backuppc/apache.conf which is symbolically linked from /etc/apache2/conf.d/backuppc.conf.
For problem analysis, I have added the following script to /usr/lib/backuppc/cgi-bin/debug.cgi:
#!/usr/bin/perl
printf("My userid is $> (%s)\n", (getpwuid($>))[0]);
The output, written in the apache error.log, after authentication, was:
My userid is 33 (www-data)
So the userid is incorrectly passed to BackupPc. The user id passed is www-data where I expected that the authenticated user id, passed to BackupPc would be backuppc as the latter is the one I used to login with. So probably, this is an apache configuration issue.
I have added a second cgi script printenv.cgi which output the environment variables. The script contains:
#!/usr/bin/perl
print "Content-type: text/plain\n\n";
foreach $var (sort(keys(%ENV))) {
    $val = $ENV{$var};
    $val =~ s|\n|\\n|g;
    $val =~ s|"|\\"|g;
    print "${var}=\"${val}\"\n";
The output contained:
REMOTE_USER="$REDIRECT_REMOTE_USER="
where backuppc requires that this environment variable REMOTE_USER contains the authenticated user (backuppc in my example). Turns out that an incorrect REMOTE_USER is the cause of the problem.
The diagnostic scripts were placed in /usr/lib/backuppc/cgi-bin/ and were symbolically linked from /usr/share/backuppc/cgi-bin/. Their ownership was backupc:www-data and they were granted chmod a+x and u+s permissions.
With the output of REMOTE_USER="$REDIRECT_REMOTE_USER=", I did a grep on REMOTE_USER in the configuration scripts below /etc/apache2/conf-enabled. I found a .conf file that contained:
SetEnv REMOTE_USER=$REDIRECT_REMOTE_USER
The .conf script was unrelated to backuppc. Prefixing the REMOTE_USER line with #, and then restarting the services
# apachtectl restart
# service backuppc restart
resolved the issue.
