I installed Oracle SQL Developer in my Ubuntu 14.04.
To set the connection, I have to use two files tnsname.ora and listener.ora.
How can I find them?
techraf
  • 3,316
  • tnsnames.ora (mind the extra s) should be in $ORACLE_HOME/network/admin/
  • listener.ora is also located in $ORACLE_HOME/network/admin/.
  • These 2 files do not have to be there. If not create them yourself using an editor.
  • $ORACLE is probably installed at /opt/ or /var/opt/. Do an echo $ORACLE.
If you do not remember where you installed it you can use locate to find them with ...
locate tnsnames.ora
locate listener.ora
locate is not real time but based on a database that stores the locations of all files since it was updated. Ubuntu updates this once a week for you. Manual update can be done with ...
sudo locatedb
Rinzwind
  • 309,379
