My Acer freezes every 10 minutes unless I use the following in Grub defaults:
GRUB_CMDLINE_LINUX_DEFAULT="quiet splash acpi_osi=Linux intel_idle.max_cstate=0 processor.max_cstate=1"
To avoid having to reenter this at every Grub update, I decided to use the 40_custom option in the /etc/grub.d folder.
However this throws up a question - will 40_custom be also modified with every kernel update version, or am I "frozen in time", forever with the kernel current at time of writing, in my case 4.4.0-15, (at least the xxx-generics)
menuentry "Ubuntu 16.04 (auf /dev/sda3)" --class ubuntu --class gnu-linux --class gnu --class os $menuentry_id_option 'gnulinux-simple-0f2bc7b3-8d86-4577-9703-c8113ca3f746' {
    recordfail
    load_video
    gfxmode $linux_gfx_mode
    insmod gzio
    if [ x$grub_platform = xxen ]; then insmod xzio; insmod lzopio; fi
    insmod part_gpt
    insmod ext2
    set root='hd0,gpt3'
    if [ x$feature_platform_search_hint = xy ]; then
      search --no-floppy --fs-uuid --set=root --hint-bios=hd0,gpt3 --hint-efi=hd0,gpt3 --hint-baremetal=ahci0,gpt3  0f2bc7b3-8d86-4577-9703-c8113ca3f746
    else
      search --no-floppy --fs-uuid --set=root 0f2bc7b3-8d86-4577-9703-c8113ca3f746
    fi
    linux   /boot/vmlinuz-4.4.0-15-generic.efi.signed root=UUID=0f2bc7b3-8d86-4577-9703-c8113ca3f746 ro  quiet splash acpi intel_idle.max_cstate=0 processor.max_cstate=1 $vt_handoff
    initrd  /boot/initrd.img-4.4.0-15-generic
Panther
  • 104,528
You are editing the wrong file. 40_custom is for adding a custom menu entry not found by grub2 and will add a single entry.
You need to edit /etc/default/grub
sudo nano /etc/default/grub
and add the kernel optionsacpi_osi=Linux intel_idle.max_cstate=0 processor.max_cstate=1 to the GRUB_CMDLINE_LINUX_DEFAULT="quiet splash line, like so
Then update grub and those options will be added to existing grub entries as well as all kernels installed via apt-get , updates, or software center.
sudo update-grub
Boot repair will do this graphically if you prefer.
To install, see https://help.ubuntu.com/community/Boot-Repair#A2nd_option_:_install_Boot-Repair_in_Ubuntu
sudo add-apt-repository ppa:yannubuntu/boot-repair
sudo apt-get update
# The last line will install and run boot-repair
sudo apt-get install -y boot-repair && boot-repair
Use the grub options tab
Panther
  • 104,528
