I want to install the ubuntu mate 16.04, I tried the ubuntu 15.10 and 14.04 and no one work, always it is showing
[ACPI : EC: Fail in evaluating the _REG object of EC device. Broken bios is suspected].
I can't install linux on my computer (MSI GP72-6QE-087XFR Leopard Pro).
Someone gave this answer:
Just start the PC with the boot option
nomodeset idle=nomwait
For asus Rog 6th generation intel just
idle=nomwait
But I don't know where is the boot option, I want to install ubuntu mate 16.04 or ubuntu 15.10.
I had the same problem with Ubuntu (16.04 & 14.04) on a "MSI GP62 Leopard Pro"
I made it to boot correctly by adding at the end of the boot line (after "quiet splash") :
nomodeset acpi_osi=
(you can access the command line by typing "e" when you see the grub ("Try Ubuntu" / "Install Ubuntu" / ...)
more information here
bloub
  • 171
In the options (try Ubuntu, install ...etc) Press E .... You will be in an editor, put the string you need in the bottom.
Don
Tested on: notebook model MSI GP72-6qe
Writing acpi=off on grub options, with this Ubuntu booted correctly, then apply all updates, in "privete controller" or "controladores privativos" (in spanish) choose Processor microcode firmware for intel . . . and reboot.
Now ubuntu run OK! with hot keys, acpi options, wifi, bluetooth, etc.
muru
  • 207,228
