Apologies, I am aware this is a common question, but I have tried numerous things and still can't get my system to update due to 100% usage of boot disk.
I have no idea what to do.
uname -r = 3.16.0-62-generic
$ df -h
Filesystem Size Used Avail Use% Mounted on
udev 4.9G 12K 4.9G 1% /dev
tmpfs 988M 1.4M 987M 1% /run
/dev/mapper/ubuntu--vg-root 107G 62G 40G 62% /
none 4.0K 0 4.0K 0% /sys/fs/cgroup
none 5.0M 0 5.0M 0% /run/lock
none 4.9G 78M 4.8G 2% /run/shm
none 100M 32K 100M 1% /run/user
/dev/sda2 237M 225M 0 100% /boot
/dev/sda1 511M 3.4M 508M 1% /boot/efi
If I try sudo apt-get autoremove, I see:
Reading package lists... Done
Building dependency tree
0 to upgrade, 0 to newly install, 0 to remove and 83 not to upgrade.
7 not fully installed or removed.
After this operation, 0 B of additional disk space will be used.
Setting up linux-image-3.16.0-62-generic (3.16.0-62.83~14.04.1) ...
Running depmod.
update-initramfs: deferring update (hook will be called later)
Not updating initrd symbolic links since we are being updated/reinstalled
(3.16.0-62.82~14.04.1 was configured last, according to dpkg)
Not updating image symbolic links since we are being updated/reinstalled
Examining /etc/kernel/postinst.d.
run-parts: executing /etc/kernel/postinst.d/apt-auto-removal 3.16.0- 62-generic /boot/vmlinuz-3.16.0-62-generic
run-parts: executing /etc/kernel/postinst.d/dkms 3.16.0-62-generic /boot/vmlinuz-3.16.0-62-generic
run-parts: executing /etc/kernel/postinst.d/initramfs-tools 3.16.0-62-generic /boot/vmlinuz-3.16.0-62-generic
update-initramfs: Generating /boot/initrd.img-3.16.0-62-generic
gzip: stdout: No space left on device
E: mkinitramfs failure cpio 141 gzip 1
update-initramfs: failed for /boot/initrd.img-3.16.0-62-generic with 1.
run-parts: /etc/kernel/postinst.d/initramfs-tools exited with return code 1
Failed to process /etc/kernel/postinst.d at /var/lib/dpkg/info/linux-image-3.16.0-62-generic.postinst line 1025.
dpkg: error processing package linux-image-3.16.0-62-generic (--configure):
subprocess installed post-installation script returned error exit status 2
dpkg: dependency problems prevent configuration of linux-image-extra-3.16.0-62-generic:
linux-image-extra-3.16.0-62-generic depends on linux-image-3.16.0-62-generic; however:
Package linux-image-3.16.0-62-generic is not configured yet.
dpkg: error processing package linux-image-extra-3.16.0-62-generic (--configure):
dependency problems - leaving unconfigured
dpkg: dependency problems prevent configuration of linux-image-generic-lts-utopic:
linux-image-generic-lts-utopic depends on linux-image-3.16.0-62-generic; however:
linux-image-generic-lts-utopic depends on linux-image-extra-3.16.0-62-generic; however:
Package linux-image-extra-3.16.0-62-generic is not configured yet.
dpkg: error processing package linux-image-generic-lts-utopic (--configure):
dpkg: dependency problems prevent configuration of linux-generic-lts-utopic:
linux-generic-lts-utopic depends on linux-image-generic-
No apport report written because the error message indicates it's a follow-up error from a previous failure.
No apport report written because MaxReports has already been reached
lts-utopic (= 3.16.0.62.53); however:
Package linux-image-generic-lts-utopic is not configured yet.
dpkg: error processing package linux-generic-lts-utopic (--configure):
dpkg: dependency problems prevent configuration of linux-signed-image-3.16.0-62-generic:
linux-signed-image-3.16.0-62-generic depends on linux-image-3.16.0-62-generic (= 3.16.0-62.83~14.04.1); however:
linux-signed-image-3.16.0-62-generic depends on linux-image-extra-3.16.0-62-generic (= 3.16.0-62.83~14.04.1); however:
dpkg: error processing package linux-signed-image-3.16.0-62-generic (--configure):
dpkg: dependency problems prevent configuration of linux-signed-image-generic-lts-utopic:
linux-signed-image-generic-lts-utopic depends on linux-signed-image-3.16.0-62-generic; however:
Package linux-signed-image-3.16.0-62-generic is not configured yet.
dpkg: error processing package linux-signed-image-generic-lts-utopic (--configure):
dpkg: dependency problems prevent configuration of linux-signed-generic-lts-utopic:
linux-signed-generic-lts-utopic depends on linux-signed-image-generic-lts-utopic (= 3.16.0.62.53); however:
Package linux-signed-image-generic-lts-utopic is not configured yet.
dpkg: error processing package linux-signed-generic-lts-utopic (--configure):
N: Ignoring file 'trillian.list.1' in directory '/etc/apt/sources.list.d/' as it has an invalid filename extension
E: Sub-process /usr/bin/dpkg returned an error code (1)`
