10
Are there any I struction for installing Nvidia and Bumblebee on 16.04? I'm trying to do a cleans install but all the procedures I've found end in a state where Ubuntu boot to low graphics mode and if you add nomodeset to the launch parameters lightdm crashes when you try to log in.
Edit: I'm just going without Bumblebee for now.
Aido
  • 532
Looks like someone has succeeded... https://lenovolinux.blogspot.si/2016/05/bumblebee-on-lenovo-t440p-nvidia-gt.html
gsedej
  • 5,024
http://help.ubuntu.ru/wiki/bumblebee-xenial
Step 1 - Add PPA:
sudo add-apt-repository ppa:neon1ks/bumblebee
Step 2 - Fully update the system:
sudo apt-get update
sudo apt-get dist-upgrade
Step 3 - Install nvidia-361 and bumblebee:
sudo apt-get install --install-recommends nvidia-361 nvidia-settings bumblebee bumblebee-nvidia primus
Step 4 - Add user to bumblebee group:
sudo gpasswd -a $USER bumblebee
Step 5 - Enable bumblebeed
sudo systemctl enable bumblebeed
Step 6 - Edit /etc/modules
sudo gedit /etc/modules
To add 2 lines to the end of the file:
i915
bbswitch
Step 7 - Edit the bumblebee configuration file:
sudo gedit /etc/bumblebee/bumblebee.conf
line 22:
Driver=nvidia
line 55:
KernelDriver=nvidia-361
line 58:
LibraryPath=/usr/lib/nvidia-361:/usr/lib32/nvidia-361
line 61:
XorgModulePath=/usr/lib/nvidia-361/xorg,/usr/lib/xorg/modules
Step 8 - Reboot
neon1ks
  • 71
For me the installation on 16.04 worked using the following way,
sudo apt-get install bumblebee nvidia-367 primus
Then, blacklist nouveau and edit the conf file
edit /etc/modprobe.d/bumblebee.conf - add the text:
blacklist nouveau
edit, /etc/bumblebe/bumblebee.conf. Here is my bumblebee configuration file:
# Configuration file for Bumblebee. Values should **not** be put between quotes
## Server options. Any change made in this section will need a server restart
# to take effect.
[bumblebeed]
# The secondary Xorg server DISPLAY number
VirtualDisplay=:8
# Should the unused Xorg server be kept running? Set this to true if waiting
# for X to be ready is too long and don't need power management at all.
KeepUnusedXServer=false
# The name of the Bumbleblee server group name (GID name)
ServerGroup=bumblebee
# Card power state at exit. Set to false if the card shoud be ON when Bumblebee
# server exits.
TurnCardOffAtExit=false
# The default behavior of '-f' option on optirun. If set to "true", '-f' will
# be ignored.
NoEcoModeOverride=false
# The Driver used by Bumblebee server. If this value is not set (or empty),
# auto-detection is performed. The available drivers are nvidia and nouveau
# (See also the driver-specific sections below)
Driver=nvidia
# Directory with a dummy config file to pass as a -configdir to secondary X
XorgConfDir=/etc/bumblebee/xorg.conf.d
## Client options. Will take effect on the next optirun executed.
[optirun]
# Acceleration/ rendering bridge, possible values are auto, virtualgl and
# primus.
Bridge=auto
# The method used for VirtualGL to transport frames between X servers.
# Possible values are proxy, jpeg, rgb, xv and yuv.
VGLTransport=proxy
# List of paths which are searched for the primus libGL.so.1 when using
# the primus bridge
PrimusLibraryPath=/usr/lib/x86_64-linux-gnu/primus:/usr/lib/i386-linux-gnu/primus
# Should the program run under optirun even if Bumblebee server or nvidia card
# is not available?
AllowFallbackToIGC=false
# Driver-specific settings are grouped under [driver-NAME]. The sections are
# parsed if the Driver setting in [bumblebeed] is set to NAME (or if auto-
# detection resolves to NAME).
# PMMethod: method to use for saving power by disabling the nvidia card, valid
# values are: auto - automatically detect which PM method to use
#         bbswitch - new in BB 3, recommended if available
#       switcheroo - vga_switcheroo method, use at your own risk
#             none - disable PM completely
# https://github.com/Bumblebee-Project/Bumblebee/wiki/Comparison-of-PM-methods
## Section with nvidia driver specific options, only parsed if Driver=nvidia
[driver-nvidia]
# Module name to load, defaults to Driver if empty or unset
KernelDriver=nvidia
PMMethod=auto
# colon-separated path to the nvidia libraries
LibraryPath=/usr/lib/nvidia-367:/usr/lib32/nvidia-367
# comma-separated path of the directory containing nvidia_drv.so and the
# default Xorg modules path
XorgModulePath=/usr/lib/nvidia-367/xorg,/usr/lib/xorg/modules
XorgConfFile=/etc/bumblebee/xorg.conf.nvidia
## Section with nouveau driver specific options, only parsed if Driver=nouveau
[driver-nouveau]
KernelDriver=nouveau
PMMethod=auto
XorgConfFile=/etc/bumblebee/xorg.conf.nouveau
Zanna
  • 72,312
If you are fine with using the open source Nouveau Drivers, you can get it working easily.
I have the Nouveau driver installed. (please see image: Driver Screenshot.png)
To install Bumblebee in Ubuntu 16.04 with Nouveau, I just used the command from the Advanced Setups Section of the Bumblebee Official Wiki page, which says:
https://wiki.ubuntu.com/Bumblebee#Advanced_Setups
"For advanced users, if you do not want to use the proprietary nvidia driver or 32-bit libraries (for example, if you are only interested in power savings), you can do a custom installation:"
And the command is
sudo apt-get install --no-install-recommends bumblebee
Reboot.
Though the section says about some more options, nothing more seemed be necessary, it started doing the job well after reboot.
Yaksha
  • 1,760
