I can't find in the Xubuntu 14.04 settings where the shortcut Ctrl+Alt+T is associated to the xfce4 terminal. I'd like to associate that shortcut to terminator. How can I do it?
Asked
Active
Viewed 6,722 times
11
If you run the command:
exo-preferred-applications
you will get a dialogue box that will allow you to configure your preferred Terminal application as default.
Below is a screenshot illustrating the dialogue box with my own preferred emulator sakura:
To manipulate the keyboard shortcuts for the now-preferred Terminal Emulator open the keyboard settings:
Applications --> Settings --> Keyboard --> Application Shortcuts
and either modify the existing shortcut or create a new one that uses this command:
exo-open --launch TerminalEmulator
You will then be prompted to type in your preferred key combination.
Below are my own settings with the appropriate keyboard setting of Ctrl+Alt+T in place for the default Terminal Emulator:
andrew.46
- 39,359
